Results 1 to 9 of 9
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    6
    Default Calculate Volume in Autocad 2012 ?
    There are points in different levels i wanna make the surfer with this points and project the surfer on the down surfer(that makes with other points) after that make an enclosed Volume and finally Calculate the Volume between this 2 surfer.
    How its possible to Calculate?
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,839
    Sounds like you would be better off using an AutoCAD vertical product like Civil 3D. Is this a site plan?
    Senior Member
    bill_borec's Computer Details
    Windows 7 - 64 Bit
    Dell XPS
    Intel i7-2600
    8 GB
    AMD Radeon HD 6700
    Dual 24"s
    Civil
    bill_borec's Discipline Details
    Civil PE
    Civil
    Water Resources (Water/Sewer/Storm) Water/Wastewater Treatment Design
    Civil 3D 2013
    Jan 2012
    43.3630N 124.1947W
    166
    Civil3D will do what you describe. You can do it manually (painfully create a solid that is the difference between the two surfaces) and use MASSPROP to get the volume. Good luck!
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    6
    Thanks so much Bill but i have problem to make surfer with points! There are many points in different levels that i should make surface with them, i need to creat tiangle between points(like Datamine studio that makes triangle between points)to make surfaces, is it possible in Civil 3D and How?
  5. #5
    SLW210's Computer Details
    Windows 7 PRO 64-bit
    IBM Lenovo
    ACPI x64
    Pentium(R) i5 4570 @ 3.2GHz
    8 GB RAM
    Nvidia Quadro 600 1GB
    300 GB
    650GB
    2x ThinkVision 24"
    Multi-disciplinary
    SLW210's Discipline Details
    Design Draftsman
    Multi-disciplinary
    AutoCAD 2018
    May 2007
    South Florida, USA
    12,043
    You might see if CADTOOLS has what you need.
  6. #6
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    6
    No its not a site plan its a Mine Block!
    We do surveying and import points in AutoCad Before the Blasting, after the blasting and loading and hauling the Rock, again we do surveying in the same Place we have new points instead of last points, Now i wanna Calculate Volume of Rock that we moved!
    is it possible?
    (the way is to make a surface with first surveying points and make another surface with second surveying points, and project the upper surface on down surface, make the wireframe and Calculate encolsed Volume!) How can i do it?
    I need to calculate plz
  7. #7
    Inventor 2015
    Sep 2007
    Williamsport, PA
    8,731
    How accurate a solution do you need?
    With AutoCAD you could create 2-4 splines and Loft the Slice with Surface from a solid.
    If you need more accuracy (using a lot of points) you will need something like c3d.
    There is a simple AutoCAD example in this tutorial http://home.pct.edu/~jmather/AU2007/...P%20Mather.pdf pg 11 or
    http://home.pct.edu/~jmather/content...torial%201.pdf pg 22 fig 40
  8. #8
    Senior Member
    Windows 7 - 64 Bit
    Dell XPS
    Intel i7-2600
    8 GB
    AMD Radeon HD 6700
    Dual 24"s
    Civil
    Civil PE
    Civil
    Civil 3D 2013
    Jan 2012
    43.3630N 124.1947W
    166
    Miner,
    C3D will do what you have described. I have done exactly that (taken existing topo survey data points before construction then survey following construction and pay the contractor based on CY actually removed - or filled depending on the job). It is as simple as establishing two different surfaces with the survey points to define them (make sure the surfaces intersect). There is a volume calculation tool that performs the analysis and a table that shows the results of the difference between the surfaces. In the volume calculation tool you use your existing as 'base' and then calculate the difference between your new surface and the 'base'. The results will only be as accurate as the survey. So, the survey has to be good (and on the same datum).
  9. #9
    Forum Newbie
    AutoCAD 2012
    Apr 2012
    6
    Bill,
    Thanks so much, if its possible give me the commands to 1. make surfaces (with alot of points beside each other in different Levels) 2. intersect those two surfaces (in different levels) 3. Calculate Volume between two surfaces
    Its my E_mail: minerman2020@yahoo.com, Ill be happy to have your E_mail
    Sincerely Yours, Sam
  1. What the complete procedure to calculate the stockpile volume?
    By RoadDesignMan in forum Civil 3D & LDD
    Last Post: 10th Sep 2011, 04:29 am
  2. Replies: 0
    Last Post: 1st Sep 2011, 04:20 am
  3. Calculate the volume of 3dfaces
    By EmperorJayP in forum AutoCAD 3D Modelling & Rendering
    Last Post: 12th Dec 2009, 10:47 pm
  4. calculate in autocad 2008 LT
    By marrius in forum AutoCAD General
    Last Post: 25th Jul 2008, 10:00 am
  5. calculate areas using AutoCad LT
    By nickcardwell in forum AutoCAD Beginners' Area
    Last Post: 14th Nov 2006, 12:20 am
