Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    Forum Newbie
    not specified
    Feb 2006
    9
    Default Right Mouse Button
    I was wondering if anyone could help me, I am using Autocad 2006. The problem is my right mouse button just keeps going to last action used, it will not pull up menus. An example is on tables, I right click and it just goes to the last action, it doesn't pull down the menu to add a row. Also I cannot double click on an object to pull up the propertise it just shows the grips. I have checked the User Preference-right click customization and it is right . Does anyone know what might have happened?
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,591
    Type in SHORTCUTMENU at the command line. What is it set to?
    R.K. McSwain
    CAD Panacea | twitter
    Forum Newbie
    not specified
    Feb 2006
    9
    It is 27
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,591
    Set it to 11 and see if this works better for you.
    27 means you have the "time-sensitive" right click turned on, meaning that you have to hold down the right mouse button longer to activate the menus.
    R.K. McSwain
  5. #5
    Forum Newbie
    not specified
    Feb 2006
    9
    It didn't make any difference. When I click on the table and right click the repeat action menu comes up and double clicking on an object still doesn't bring up properties. It use to, I don't know what I did.
  6. #6
    Senior Member
    not specified
    Feb 2006
    Guelph, Ontario
    436
    You can also type in "options" at the command prompt and go to user preferences and look at the way that you have your right click customizations set.
    Mike
  7. #7
    Forum Newbie
    not specified
    Feb 2006
    9
    I have looked at the user preference, right click customizations and it looks good
    Time sensitive right click is checked
    Longer click duration is set at 250 milliseconds
    Edit Mode is set on short cut menu
    If I uninstall Autocad and then reinstall, when I open up my drawing again will it keep its previous setting or will it go to the new settings?
  8. #8
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,591
    Quote Originally Posted by blondie
    R.K. McSwain
  9. #9
    Windows 10
    HP Z240
    i7-7700k @ 4.20GHz
    64GB
    Nvidia Quadro P1000
    0.5TB SSD
    1TB SATA
    Vizio 40"
    Civil
    Civil 3D 2019
    Sep 2005
    Houston
    4,591
    Quote Originally Posted by Blondie
    Before you do that...
    Have you customized the menus any?
    What mouse are you using?
    With what drivers?
    Are you positive that your right mouse button is mapped to the right mouse click function (this is a setting in your mouse driver software)
    R.K. McSwain
  10. #10
    Forum Newbie
    not specified
    Feb 2006
    9
    I haven't done anything that I know of. Of course I must have done something, but I have being using the same programs and mouse for the past 6 months and this is the first time this has happened. I haven't install anything either.
    My right click on my mouse seem to be working fine in other programs.
