enemigoman Posted April 26, 2012 Share Posted April 26, 2012 Hello: I am using a dimension style that annoyingly adds the number "1/8" at the end of every angular dimension. Linear dimensions are fine. I already checked and there is no suffix specified in the style. I also tried the dim/up feature, but the "1/8" still appears. Degrees in "Units" are set to decimal. They are also set in decimal within the dimstyle. Just to clarify, the number "1/8" is added after the actual dimension. I drew a 90 deg rectangle and the dim shows 90 1/8. I could certainly try to create a new dimstyle from scrap, but perhaps someone here has a better tip. Thanks, Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 26, 2012 Share Posted April 26, 2012 Can you post a file with the errant dim style? Quote Link to comment Share on other sites More sharing options...
rkent Posted April 26, 2012 Share Posted April 26, 2012 Sounds like you have a font being used that converts a degree symbol to 1/8, it probably use other fractional substitutions for other characters as well. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 26, 2012 Share Posted April 26, 2012 I didn't catch that it is for angular dimensions only. I agree with rkent, seen it before. Quote Link to comment Share on other sites More sharing options...
enemigoman Posted April 26, 2012 Author Share Posted April 26, 2012 RobDraw and rkent: Thank you su much. Even though I totally failed to explain that I was using an unconventional font, you figured it out correctly. That is indeed the problem and now I am in the process of fixing it. Best regards, Quote Link to comment Share on other sites More sharing options...
