jezaride Posted April 27, 2012 Share Posted April 27, 2012 Hi Krew How do I measure the weight of some steel objects in autocad 2012 ? For instance if you draw a 10mm plate 2 meters by 1 meter ? Are there any plug-ins or extra programs that help with steel shop manufacturing detailing etc when drawing in Autocad? Thanks! JR Quote Link to comment Share on other sites More sharing options...
Dadgad Posted April 27, 2012 Share Posted April 27, 2012 (edited) Welcome to the forum. If you are talking about a 3D model you can use MASSPROP. I have never used it, but I believe that PROSTEEL can do that for you automatically, and no doubt there are a bunch of other plug-ins or lisp routines that will do that for you. I do it with custom variables, which are FUNCTIONS (not constants), which saves having to enter the multiplication icon every time it is used.. If I click on a closed polyline, the area is displayed in my quick properties palette, by clicking the calculator icon in the area attribute box there, you can easily double click the variable describing the plate thickness times the weight of a cubic unit of steel, resulting in the weight. The image shows weight being calculated from a model with the MASSPROP command. Edited April 27, 2012 by Dadgad Quote Link to comment Share on other sites More sharing options...
swats Posted April 27, 2012 Share Posted April 27, 2012 I use the massprop command and an excel spreadsheet calculator I made up. Quote Link to comment Share on other sites More sharing options...
jezaride Posted April 27, 2012 Author Share Posted April 27, 2012 Thanks Ill use volume then 7845km/m3. works a treat! Quote Link to comment Share on other sites More sharing options...
