Page 2 of 2 FirstFirst 1 2
Results 11 to 15 of 15
  1. #11
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,373
    Be sure to read, understand, and follow the instructions for installation provided by Autodesk. They have some very specific requirements for MS updates, .net framework, virus protections, etc.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  2. #12
    Full Member
    Dormant's Computer Details
    WINDOWS 7 ULTIMATE
    HP Z800 WORKSTATION
    2 x XEON X5650 @ 2.67GHz
    24 GB
    NVIDIA QUADRO 6000
    2 x DELL U2711
    AutoCAD 2013
    Oct 2011
    27
    Got AutoCAD up and running. Figured out it was running when logged in as an admin, but not as a user. After a bit of playing around IT deleted some files from registry and AutoCAD decided to configure itself and load. So all good now.
    Thanks for all the help.
  3. #13
    Forum Newbie
    AutoCAD 2013
    Aug 2012
    2
    Quote Originally Posted by Dormant View Post
    Hey Dormant,
    Do you think you could post the solution/get your IT guys to post the solution (which reg keys)? I'm trying to make this work in a school environment where no one runs as administrator.
    Cheers,
    Nick
  4. #14
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Welcome to the forum.
    This is not really my field of expertise, but can't you change this in the PROPERTIES of the desktop shortcut?
    On the SECURITY tab, or you may need to use the Advanced options?
    I believe that as an administrator you can specify a new user group and permission settings for that group.
  5. #15
    Forum Newbie
    AutoCAD 2013
    Aug 2012
    2
    Cheers AutoCAD isn't really my field
    You can run it elevated from there if it was a standalone computer, but we're running on pretty locked-down domain-joined systems.
    I've packaged and sequenced maybe a hundred apps in the last few years - I've never met anything so hideous as Autodesk Design Academy. There are so many little things you have to tweak to get it to deploy properly and no documentation on any of it T_T
  1. AutoCAD 2013 What's New
    By jdits7 in forum AutoCAD General
    Last Post: 25th Oct 2012, 03:38 pm
  2. Autocad 2013
    By Raudel Solis in forum AutoCAD General
    Last Post: 30th Apr 2012, 06:56 pm
  3. AutoCAD 2013 Bug ?!?!?
    By Oppie in forum AutoCAD General
    Last Post: 24th Apr 2012, 05:36 pm
  4. AutoCAD 2013
    By dtaylor in forum Feedback
    Last Post: 29th Mar 2012, 09:14 pm
  5. Big Day for AutoCAD 2013
    By AutoCAD Insider in forum AutoCAD RSS Feeds
    Last Post: 27th Mar 2012, 09:50 pm
