+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Super Member Bill Tillman's Avatar
    Using
    AutoCAD 2013
    Join Date
    Oct 2008
    Location
    Miami, FL
    Posts
    870
    Default Change Dimension Text pos vert
    A few months ago after much hair pulling and some advice here and there I came up with this nice snippet which changes the TextOverride for a dimension that is the (entlast).
    Code:
    (vlax-put-property (vlax-ename->vla-Object (handent (cdr (assoc 5 (entget (entlast))))))
        "TextOverride" "<>\\PFRAME OPENING")
    Today I was asked if we could rotate the dimension 90° counterclockwise so I tried this:
    Code:
        "Rotation" (dtr -90.0))
    and bingo, it worked like Lee-Mac or Fixo had written it themselves for me. The request also came to adjust the Text vert pos to "Above" instead of "Centered". So I thought cool, I'll just try it like this:
    Code:
        "Textposvert" "Above")
    but no such luck. I end up with:
    Error: ActiveX Server returned the error: unknown name: Textposvert
    I tried all kinds of variations for Textposvert, (Text Pos Vert, posvert, pervert....) anything to see what might work. But so far nothing is working. I was hoping this would be just as straight forward as the first solution.
    This is for my totally automated process...no user input is allowed, only code for a solution. Any suggestions would be appreciated.
    It's deja vu, all over again.
  2. #2
    Quantum Mechanic Lee Mac's Avatar
    Computer Details
    Lee Mac's Computer Details
    Operating System:
    Windows 7 Ultimate (32-bit)
    Discipline
    Multi-disciplinary
    Lee Mac's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Custom Programming / Software Customisation
    Using
    AutoCAD 2013
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    15,718
    Default
    Bill,
    Aside from your question, have a think about what this expression is doing:
    Code:
    Lee Mac Programming
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
    Just another Swamper
  3. #3
    Computer Details
    Operating System:
    Discipline
    Multi-disciplinary
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2013
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    15,718
    Default
    You receive the error because a Dimension object does not have the property 'textposvert'. If you are planning on just guessing the names of properties that VLA-Objects possess, then prepare for a long time spent pulling your hair out...
    Instead, consider using the vlax-dump-object function in conjunction with the ActiveX & VBA Reference as part of the Visual LISP IDE Help Docs.
    After a quick check with the above function, I can see that the property you require is the TextGap property. However, note that this will be applied as a Dimension Style Override!
    Lee Mac Programming
  4. #4
    Computer Details
    Operating System:
    Discipline
    Multi-disciplinary
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2013
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    15,718
    Default
    Did you resolve this Bill, or have I wasted my time?
    Lee Mac Programming
  5. #5
    Using
    AutoCAD 2013
    Join Date
    Oct 2008
    Location
    Miami, FL
    Posts
    870
    Default
    Lee,
    I appreciate your interest. I've been distracted with some new assignments this week and some health issues. I plan to get back on this by Monday. The users are presently satisfied but that won't last long. Thanks again.
Similar Threads
  1. Can't change dimension text size
    By Bill T in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2011, 02:33 am
  2. Profile Vert./Hor.
    By nyaromulo in forum Civil 3D & LDD
    Last Post: 2nd Apr 2009, 10:00 pm
  3. How to read polyline vert to file with name?
    By iztok13 in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Jan 2009, 01:18 pm
  4. Change Dimension Value
    By CAD<LIFE in forum AutoCAD Beginners' Area
    Last Post: 21st Jul 2008, 04:45 pm
  5. cant change dimension text size
    By b.muqlueen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Feb 2008, 03:46 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
