+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Full Member
    Using
    MEP 2012
    Join Date
    Jan 2010
    Location
    Seattle WA
    Posts
    72
    Default Change text size multiple
    Does anyone have the change text size multiple lisp? I used to have one a while ago.
    Thank you for your time,
    effeezy
  2. #2
    Quantum Mechanic Lee Mac's Avatar
    Computer Details
    Lee Mac's Computer Details
    Operating System:
    Windows 7 Ultimate (32-bit)
    Discipline
    Multi-disciplinary
    Lee Mac's Discipline Details
    Discipline
    Multi-disciplinary
    Details
    Custom Programming / Software Customisation
    Using
    AutoCAD 2013
    Join Date
    Aug 2008
    Location
    London, England
    Posts
    15,707
    Default
    Select Text > Properties Panel > Text Height?
    Lee Mac Programming
    With Mathematics there is the possibility of perfect rigour, so why settle for less?
    Just another Swamper
  3. #3
    Forum Deity BlackBox's Avatar
    Using
    Civil 3D 2011
    Join Date
    Nov 2009
    Posts
    3,932
    Default
    Select an instance of the desired text entities to be changed, the use the [Aec]SelectSimilar Command, then change the Text Height in the Properties Pane (Ctrl+1).
    "Potential has a shelf life." - Margaret Atwood
Similar Threads
  1. Can't change dimension text size
    By Bill T in forum AutoCAD Beginners' Area
    Last Post: 24th Aug 2011, 02:33 am
  2. Change multiple Dimensions measured text into normal text?
    By apsonwane in forum AutoLISP, Visual LISP & DCL
    Last Post: 1st Jun 2011, 09:31 am
  3. How to change text size
    By sharpooth in forum AutoLISP, Visual LISP & DCL
    Last Post: 29th Apr 2010, 07:14 pm
  4. 'Can't seem to get dim text size to change...
    By dpaulku in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Jun 2009, 01:19 am
  5. cant change dimension text size
    By b.muqlueen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 22nd Feb 2008, 03:46 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
