Inventor 2010 drawing problem...
hekri
Hello guys,
I need help with a drawing in Inventor (2010).
My problem is this: I have to make a section view of a part but I don't wanna section the whole part cause I need to dimension it, I just have to make partial section of the part, i want to show the hole down there.
I have attached a pdf file of the part. This is how it should look. (it's drawn in AutoCAD).
If someone could take a look at it.
Thank you in advance.
P.S I apologize for my bad English, it's not my native language.
123.pdf
For what you want here, you need to create a Break Out view.
Select your view and then select to Create a New Sketch
Use Project Geometry to locate your cutout shape on your view
Finish the Sketch
Start the Break Out command
Select your sketch and depth options.
