Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 26
    Junior Member
    AutoCAD 2011
    May 2012
    Hobart,Tasmania,Australia
    14
    Default best method for creating a 2D p/line for NC routing from 3D solid?
    Well this is driving me bonkers.. yes ,i have discovered a 3D polyline cant be joined to a 2D polyline and when i exploded 3Dpline then flattened it ,as recommended elsewhere on this forum,it seems its shrunk in length.The NC router I have access to has to use 2D polyline for the path of the cutter.I soooo wish i could simply fed the 3D object into the NC router software and that was all i had to do .Suggestions ,folks ?
    Junior Member
    AutoCAD 2011
    May 2012
    14
    oops...forget to mention I am running 2011 AutoCad.I have tried exploding solid/pedit to convert spline to 3D polyline/flatten it,but this is no good it seems.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Can you post a copy of the drawing wherein you have a 3Dpolyline and a 2Dpolyline that cannot be joined?
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Quote Originally Posted by ZedEverett View Post
    When you say that it shrunk in length? Wouldn't that be a logical consequence of removing travel along the Z axis?
    When measured from WORLD UCS it would appear to be the same length, although in actuality it would have been shortened, when measured in 3D.
    I'm with ReMark, skeptical about your claim that it cannot be joined to the 2D polyline. Happy to try if you post it, or maybe just those 2 particular lines from your drawing.
  5. #5
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    I'm not skeptical. I have 2013 installed. The Join command will connect a 3Dpolyline to a 2Dpolyline.
  6. #6
    AutoCAD 2012
    Nov 2011
    3,134
    That was my position too, I find it hard to believe that it can't be done (skeptical, if you will of the OPs conclusion). Remembering that he is on 2011 I still feel that there must be a way, without availing ourselves of that new functionality in 2013.
  7. #7
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    I think it best the OP try JDM's suggestion despite the fun we have had at his expense.
  8. #8
    AutoCAD 2012
    Nov 2011
    3,134
    FIRE IN THE HOLE!
    Hell, I still want a shot at joining them, but we haven't been able to coax or cajole a sample yet!
    And yeah explode would probably be my first step right out of the gate.
  9. #9
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Since I was curious about this I conducted a simple test.
    I drew a 2Dpolyline and a 3Dpolyline (separate layers/colors) then used the JOIN command on them. I checked the Properties of the combined line AFTER joining them. AutoCAD said I now had a polyline. It made no difference which one I picked first when I executed the JOIN command.
  10. #10
    AutoCAD 2012
    Nov 2011
    3,134
    That would be using 2013 I imagine? On differing planes?
  1. Creating new routing preferences and catalog
    By blackeagle1245 in forum MEP
    Last Post: 24th Jan 2011, 11:20 pm
  2. Replies: 12
    Last Post: 26th Sep 2010, 02:36 am
  3. Creating a Solid
    By nicnicman in forum AutoCAD 3D Modelling & Rendering
    Last Post: 26th Oct 2008, 11:28 pm
  4. Having trouble creating solid
    By Cadastrophic in forum AutoCAD 3D Modelling & Rendering
    Last Post: 3rd Jul 2008, 06:30 pm
  5. Creating 3D solid
    By careyc in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Mar 2005, 08:48 pm
