change the pdmode.
I have exported one point file from arc gis software to autocad. It is opening in autocad but I 'am not able to change the size of those points. Though I can change the color. I also created a small symbol and tried to match it by using MA option but it is not of any use.
Thanks,
Shilpika
change the pdmode.
The said PDMODE system variable controls only the appearance of points; check also PDSIZE for display size.
You can have control for both through DDPTYPE command.
Regards,
Mircea
AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
