action macro - how to select last layout tab
Scripts are not my strongest skill, so I hope to find some basic help.
I want to make a action macro that selects the copy the last layout tab, copy that, goes modelspace and -pan @some numbers, go back in modelspace. stop.
I've recorded the following steps succesfully:
Layout
copy
and
mspace
-pan
(basepoint plus some mumbers)
(@-3000,0)
I would like to know the command for selecting the last layout tab. Without using right-click functions which, as I know of, are not recorded?
Hope someone can help :)
This is the code for getting a list of layout tabs not sure if last is first
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vlax-for lay (vla-get-Layouts doc)
 (setq plotabs (cons (vla-get-name lay) plotabs))
(setq lasttab (nth 1 plotabs )) ;or (cadr plotabs)
  • 3 weeks later...
