Figuring out this Sweep command... Guitar body
B_Rich
Body.iptMy buddy is making his own guitar, and he isn't sure what he wants to do for a round over-type design around the edge, so he drew up the body and gave it to me to see if I can get something on there. Hopefully you can see it well enough, but I'm trying to sweep the triangle profile around the edge of the guitar, but I'm running into a problem. The triangle isn't staying perpendicular with the edge of the guitar... any ideas on how to accomplish this? Here is an example of a guitar that has it done. The chamfered around the edge is what I'm after.
The file is attached, along with some screen shots:
  • 3 weeks later...
The cut sketch needs to be perpendicular to the sweep. The easiest way to do this is to create a sketch point on the sweep line, and create a work plane by point and line. Create your cut sketch on this line.
Don't forget to fully constrain your cut sketch!
