Results 1 to 3 of 3
    Full Member
    AutoCAD 2009
    May 2011
    52
    Question MEP pipe Elevation with Two Finished Floor Elevations
    I have to put some BOP labels on my drawing, but there are two different finished floor heights in the drawing. They wanted us to keep the areas on the same drawing for coordination purposes, but now I need to know how to set up a label with different FF elevations (like one at 0' and another at 4'). Any suggestions?
    P.S. D3 Advertisement on CADTutor, lol.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,495
    Are you using the Project Navigator with Constructs & Views? This is the only way I see it possible.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
    Full Member
    MEP 2013
    Jun 2012
    31
    Quote Originally Posted by Epicurwin View Post
    You can add a manual property definition to the pipe object property set. Call that property definition "Elevation Offset". Then go into the bottom of pipe calc formula definition and subtract the manual definition. Then you can just edit the elevation offset value for pipes that need it.
    Alternatively a much more elegant solution would be to add the elevation offset to a space object and then in the pipe object property definition you could add a location based property definition that points to the space elevation offset. Now just draw a space around the area with the raised / lowered floor and set the elevation offset in the space. Now any pipes going thru the space will pick up the new offset and use it. Once set up in your template this is the easiest and fastest method for getting your pipe offsets correct. This way you don't have to set up alot of false levels or clickneach pipe to set the offset.
  1. draw elevation of 3 floor building
    By pt3 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 18th Nov 2010, 02:56 am
  2. Multi-floor elevation
    By ARR in forum AutoCAD Beginners' Area
    Last Post: 21st Mar 2010, 04:22 pm
  3. Attach top floor to bottom floor.
    By K-Ro0 in forum AutoCAD General
    Last Post: 2nd Dec 2007, 03:08 am
  4. From floor plan to elevation
    By nathan008 in forum AutoCAD General
    Last Post: 24th Oct 2007, 11:27 am
