+ Reply to Thread
Results 1 to 5 of 5
  1. #1
    Full Member grasshopper's Avatar
    Using
    AutoCAD 2008
    Join Date
    Oct 2006
    Posts
    44
    Default cannot uninstall autoCAD 2009
    I'm attempting to uninstall autoCAD 2009, I keep getting a message reading:
    - Error opening installation log file. Verify that the specified log file location exists and that you can write to it.
    I have located the install log..... no what.
    Thanks in advance
  2. #2
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,181
    Default
    On the Autodesk website there are very specific instructions for uninstalling their software. You might want to check there.
    Volume and repetition do not validate opinions forged in the absence of thought.
  3. #3
    Senior Member daft vader's Avatar
    Using
    MEP 2008
    Join Date
    Jul 2006
    Location
    uk
    Posts
    171
    Default
    I always keep my older versions Installed, as some times I find I like doing certain things with the older version
    Am I alone in this or do others do this as well ?
  4. #4
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    Posts
    3,181
    Default
    I tend to clean house when I have to, occasionally using a previous version, like with 2013, for instance.
    Interested by it, but not yet worth the aggravation of using it full time, so still using 2012, until they get it sorted out.
  5. #5
    Senior Member the ber's Avatar
    Using
    AutoCAD LT 2013
    Join Date
    Nov 2006
    Location
    Germany
    Posts
    187
    Default
    You need administrator rights to the pertinent files. If you are a restricted user on your computer, then you won't be able to install or uninstall such programs.
    Sooner or later, you'll own Generals.
Similar Threads
  1. Autocad 2011- Clean uninstall.
    By oldhealey in forum Software & Licensing
    Last Post: 8th Oct 2012, 01:08 pm
  2. Can't uninstall AutoCAD 2006
    By Jennyc in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 21st Jan 2012, 01:08 pm
  3. VBScript to Uninstall AutoCAD 2011
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 8th Dec 2010, 11:30 am
  4. autocad 2009 won't uninstall
    By spursnutter in forum AutoCAD General
    Last Post: 4th Sep 2009, 04:58 pm
  5. Uninstall then reinstall AutoCAD LT 2008
    By uddfl in forum Software & Licensing
    Last Post: 27th Jun 2009, 06:25 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
