+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,131
    Default
    I'm running 2013 on an old Vista-32bit machine, and it works fine, when it isn't busy screwing up older drawings.
    Volume and repetition do not validate opinions forged in the absence of thought.
  2. #12
    Senior Member
    Using
    AutoCAD 2007
    Join Date
    Dec 2006
    Posts
    207
    Default
    Quote Originally Posted by JD Mather View Post
    I am running 2012 on an old Vista 32-bit machine (the processor is actually 64-bit, but the machine was manufactured at the beginning of the 64-bit processors and there were not many drivers for 64-bit, thus the 32-bit OS).
    It is generally not possible to obtain older releases
    unless you already have the license or are a student. (the Autodesk student site goes back 3 releases).
    Nice point, I've been meaning to ask this, but anyway my university can give me access access to older versions if needed. For the moment I installed 2013 to try and see if it can run, but i encounter some issues. I opted not to install this new Autodesk Fusion 2013 software, and also i unchecked license manager from tools and utilities.
    Now as soon as i launch i dont get the ribbon menu, and i get greeted by this. Does it matter that i chose not to install the aforementioned, or did something else go wrong in the installation? Can somebody make something from the following errors, and possibly how to fix things?
    See the end of this message for details on invoking
    just-in-time (JIT) debugging instead of this dialog box.
    ************** Exception Text **************
    System.InvalidProgramException: Common Language Runtime detected an invalid program.
    at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker (MethodInfo mi, Object commandObject, Boolean bLispFunction)
    at Autodesk.AutoCAD.Runtime.CommandClass.InvokeWorker WithExceptionFilter(MethodInfo mi, Object commandObject, Boolean bLispFunction)
    at Autodesk.AutoCAD.Runtime.CommandClass.Invoke(Metho dInfo mi, Boolean bLispFunction)
    at Autodesk.AutoCAD.Runtime.CommandClass.CommandThunk .Invoke()
    ************** Loaded Assemblies **************
    mscorlib
    Assembly Version: 4.0.0.0
    Win32 Version: 4.0.30319.17379 built by: FXBETAREL
    CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
    Acdbmgd
    Assembly Version: 19.0.0.0
    Win32 Version: 19.0.55.0.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcdbMgd.DLL
    System
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    System.Core
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    AdApplicationFrame
    Assembly Version: 0.0.0.0
    Win32 Version: 3.5.19.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AdApplicationFrame.DLL
    AdWindows
    Assembly Version: 3.5.21.0
    Win32 Version: 3.5.21.0
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AdWindows.DLL
    PresentationFramework
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.dll
    WindowsBase
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
    PresentationCore
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_32/PresentationCore/v4.0_4.0.0.0__31bf3856ad364e35/PresentationCore.dll
    System.Xaml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xaml/v4.0_4.0.0.0__b77a5c561934e089/System.Xaml.dll
    System.Xml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    PresentationFramework.Aero
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework.Aero/v4.0_4.0.0.0__31bf3856ad364e35/PresentationFramework.Aero.dll
    System.Drawing
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    accoremgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/accoremgd.DLL
    Acmgd
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/Acmgd.DLL
    System.Configuration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    AcWindows
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcWindows.DLL
    AcCui
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/AcCui.DLL
    PresentationFramework-SystemXml
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXml/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXml.dll
    WindowsFormsIntegration
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/WindowsFormsIntegration/v4.0_4.0.0.0__31bf3856ad364e35/WindowsFormsIntegration.dll
    AcWindows.resources
    CodeBase: file:///C:/Program%20Files/Autodesk/AutoCAD%202013/en-US/AcWindows.resources.DLL
    PresentationUI
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationUI/v4.0_4.0.0.0__31bf3856ad364e35/PresentationUI.dll
    System.Xml.Linq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml.Linq/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.Linq.dll
    PresentationFramework-SystemXmlLinq
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/PresentationFramework-SystemXmlLinq/v4.0_4.0.0.0__b77a5c561934e089/PresentationFramework-SystemXmlLinq.dll
    System.Windows.Forms
    CodeBase: file:///C:/Windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    ************** JIT Debugging **************
    To enable just-in-time (JIT) debugging, the .config file for this
    application or computer (machine.config) must have the
    jitDebugging value set in the system.windows.forms section.
    The application must also be compiled with debugging
    enabled.
    For example:
    <configuration>
    <system.windows.forms jitDebugging="true" />
    </configuration>
    When JIT debugging is enabled, any unhandled exception
    will be sent to the JIT de****** registered on the computer
    rather than be handled by this dialog box.
  3. #13
    Senior Member
    Using
    AutoCAD 2007
    Join Date
    Dec 2006
    Posts
    207
    Default
    Could it be because i'm running Windows 8 preview? I still havent managed to solve this error, but i found a guy with the simillar message, that also runs Win 8.
    http://www.facebook.com/photo.php?fb...4219475&type=1
    EDIT: Hmm, i also found this lot, which people say its not supported on win 8 and gives lots of errors...
    http://worldcadaccess.typepad.com/bl...windows-8.html
Similar Threads
  1. Replies: 9
    Last Post: 16th Nov 2010, 03:56 pm
  2. Student Version Inventor to Regular Version
    By bdanielson in forum Autodesk Inventor
    Last Post: 15th Oct 2010, 10:22 pm
  3. How to save higher version drg to lower version drg?
    By kart_trik in forum AutoCAD Drawing Management & Output
    Last Post: 21st Aug 2008, 07:38 pm
  4. How to save higher version drg to lower version drg?
    By kart_trik in forum Tutorials & Tips'n'Tricks
    Last Post: 17th Jan 2008, 02:31 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
