Problem to plot image - help
kintal
good afternoon
I have autocad 2012 version, and I'm working on a file or other, and putting real images, with no background in. Png or. Tiff that happens is that after moving them through the contours of the ImageFrame, is all right until the time to print.
Autocad screen, the image appears without any contour, and when I do the print preview, but once print, some images appear with a green line on one side or two, never any more. But it is random, it can put several identical pictures, and some appear and no other. I tried the first pass to PDF and then print only but it happens exactly the same.
Must be some option in my autocad. For the same images on other computers do not appear any contours. Someone can help me? Is it something I have misconfigured?
thank you
yes
I type the command ImageFrame and choose 0 for no border does not appear, but these still appear green lines
What happens is that even choosing the same image, and repeating it several times, ones appear green lines and not in others. even if they are all equal
I tried to put here somo images, but becuse of the permissions, i need to have the aprove from the mood...
because they are images of people and trees, and they are to put an architectural project. So far I have used blocks of people, trees and cars, but I want to give more realism to put images in real work.
the problem is that these lines appear
these images are images with no background in. tiff or png.
