+ Reply to Thread
Results 1 to 3 of 3
  1. #1
    Forum Newbie
    Computer Details
    cragerous's Computer Details
    Operating System:
    Windows 7
    Computer:
    Shuttle
    Discipline
    Electrical
    cragerous's Discipline Details
    Occupation
    Draftsman
    Discipline
    Electrical
    Details
    I draw 3d models of power stations and equipment
    Using
    AutoCAD 2013
    Join Date
    Jun 2011
    Location
    New Zealand
    Posts
    3
    Default Defining wblock insertion point
    Can someone tell me if there is a variable that fixes this annoying problem! In previous CAD versions whenever i created a block and defined the insertion point. the block would insert where I defined it. However now whenever i insert a block I've defined it inserts from the 0,0,0 point inside the block which renders the defined insertion point useless. I don't want to have to keep opening up the blocks i create and using the insbase command to reset the insertion point it defeats the purpose of defining the block in the first place. Its also a nuisance moving the block from your defined point to 0,0,0 before wblocking it so it inserts correctly.
    Has anyone else had this problem and is it fixable
    There is nothing wrong with my install. Seems Autodesk have added another feature that needs to be set back to default.
  2. #2
    Senior Member Blackfish's Avatar
    Using
    AutoCAD LT 2012
    Join Date
    Apr 2012
    Posts
    182
    Default
    When you use wblock command for an existing block from list AutoCAD saves exploded and placed in 0,0 (World UCS) wherever the insertion point (IP) was in the block geometry in new file i.e. if IP was a center of a circle the circle is placed in a new file exactly with the center in 0,0 point of World UCS.
    When you use wblock for objects by picking them from a drawing, that could be an existing block as well, AutoCAD placed objects (block is still a block, not exploded) in a new file keeping their orginal position according to 0,0 point in the drawing from which you use wblock.
    To be honest I do not understand your problem. Can you explain it once again?
  3. #3
    Senior Member
    Computer Details
    bill_borec's Computer Details
    Operating System:
    Windows 7 - 64 Bit
    Computer:
    Dell XPS
    CPU:
    Intel i7-2600
    RAM:
    8 GB
    Graphics:
    AMD Radeon HD 6700
    Monitor:
    Dual 24"s
    Discipline
    Civil
    bill_borec's Discipline Details
    Occupation
    Civil PE
    Discipline
    Civil
    Details
    Water Resources (Water/Sewer/Storm) Water/Wastewater Treatment Design
    Using
    Civil 3D 2013
    Join Date
    Jan 2012
    Location
    43.3630N 124.1947W
    Posts
    166
    Default
    I have run into this before...I have had to reselect the insertion point 2-3 times while creating the wblock (from the wblock create window). You may try paying particular attention to the order in which you are creating the block...when creating the wblock, run the command (click the icon), then select the objects, then select the insertion point, then apply. And see if you can catch acad resetting the insertion point.
    Hope this helps.
Similar Threads
  1. MOVING THE BASE POINT/ INSERTION POINT
    By nwmjdp in forum AutoCAD Beginners' Area
    Last Post: 13th May 2012, 06:44 am
  2. Insertion point/Basepoint
    By MisterJingles in forum AutoCAD Beginners' Area
    Last Post: 6th Oct 2009, 02:13 pm
  3. Point Insertion Lisp
    By jaylo23 in forum AutoLISP, Visual LISP & DCL
    Last Post: 18th Nov 2008, 02:37 pm
  4. Problems with wblock insertion
    By WBFD22 in forum AutoCAD Beginners' Area
    Last Post: 17th Jul 2008, 04:09 am
  5. Insertion Point
    By GIB39 in forum AutoCAD Beginners' Area
    Last Post: 12th Oct 2007, 07:47 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
