Views won't display/Items won't display
glubad55
I've been using AutoCAD 2011 for several months, and I'm familiar with most properties such as layers, etc.
I have 2 separate issues, which I'll explain separately.
Issue 1.
I have 6-7 named views (same drawing) that I use consistently. However, only 2 of them will cause them to show up.
Example: I click View #3 from Views #4,#5,or #6. Nothing happens or changes.
OR I can click View #1 or #2 (which will regen/show View #1 or #2), then quickly click View #3 during #1's regeneration, and View #3 regenerates clearly.
What can I do to make the others show up independently (just one click required)?
Issue 2.
In 2 views in the drawing mentioned above, a couple of blocks don't show up with the rest of the views. If I enter the Regen command, and then they'll show up. If I hadn't tried it the first time, I would have probably missed the blocks entirely and re-created them.
What can I do to make them regenerate correctly the first time?
Thanks for any ideas you have.
Type in REGENAUTO and set to 1 and see if that helps.
Automatic regeneration of the drawing.
0 Turns off the REGENAUTO command
1 Turns on the REGENAUTO command
