Results 1 to 5 of 5
    Full Member
    Electrical
    btraemoore's Discipline Details
    Electrical Designer
    Electrical
    Electrical 2012
    Apr 2012
    Houston
    55
    Default declaration of a public varible
    declaring a public variable, this is the syntax i used... i cant get it to keep the variable public. it just loses the value after the sub is ran
    here is what i have
    Code:
    Public m_letter As String, m_number As String
    'end public varible declaration
    Sub MRevs()
        Dim gpCode(1) As Integer
        Dim dataValue(1) As Variant
        Dim SS_WFrev As AcadSelectionSet
        SS_delete 1
        Set SS_WFrev = ThisDrawing.SelectionSets.Add("SS_WFrev")
            gpCode(0) = 0: dataValue(0) = "INSERT"
            gpCode(1) = 2: dataValue(1) = "WFREV"
            SS_WFrev.Select acSelectionSetAll, , , gpCode, dataValue
            Dim Cur_Blk As AcadBlockReference
            Dim Blk_Atts() As AcadAttributeReference
            Dim Cur_att As AcadAttributeReference
            Dim i As Integer, n As Integer
            For i = 0 To SS_WFrev.Count - 1
                Set Cur_Blk = SS_WFrev.Item(i)
                Blk_Atts = Cur_Blk.GetAttributes
                For n = 0 To UBound(Blk_Atts)
                    Set Cur_att = Blk_Atts(n)
                    If Cur_att.TagString = "REVNO" Then
                        If IsNumeric(Cur_att.TextString) Then
                            If Cur_att.TextString > m_number Then
                                m_number = Cur_att.TextString
                            End If
                        Else
                            If Cur_att.TextString > m_letter Then
                                m_letter = Cur_att.TextString
                            End If
                        End If
                    End If
                Next n
            Next i
    End Sub
    Sub changerevtri()
        Dim SS_Revtag As AcadSelectionSet
        SS_delete 1
        Set SS_Revtag = ThisDrawing.SelectionSets.Add("SS_Revtag")
            gpCode(1) = 2: dataValue(1) = "revtag"
            SS_Revtag.Select acSelectionSetAll, , , gpCode, dataValue
            For i = 0 To SS_Revtag.Count - 1
                Set Cur_Blk = SS_Revtag.Item(i)
                    If Cur_att.TagString = "REV#" Then
                        Cur_att.TextString = m_number
                    End If
                Next n
            Next i
        Application.Update
    End Sub
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    You should leave the question in place and post the answer too. That way others could learn from you.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Super Member fixo's Avatar
    fixo's Computer Details
    Windows 7
    E7500
    Intel(R)Core(TM)2 DUO CPU 2.93HGz
    4098 Gb
    1024 Gb
    AutoCAD 2009
    Jul 2005
    Pietari, Venäjä
    1,586
    Quote Originally Posted by fuccaro View Post
    Glad you worked up
    The soul is healed by being with children. - Fyodor Dostoyevsky, novelist (1821-1881)
    Full Member
    Electrical
    Electrical Designer
    Electrical
    Electrical 2012
    Apr 2012
    Houston
    55
    Okay, i figured out my problem. when i set the pubic variables i set them in between two different subs. To have your variables public and accessible they have to be at the very top of the module you are working on... above all subs just like the example coding.
  5. #5
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    3,932
    "Potential has a shelf life." - Margaret Atwood
  1. Alternative coordinate declaration VB
    By 16horse in forum .NET, ObjectARX & VBA
    Last Post: 15th Dec 2010, 05:32 pm
  2. system varible settings
    By kingisland99762 in forum AutoCAD Beginners' Area
    Last Post: 29th Jan 2010, 10:35 pm
  3. A simple .dcl probblem, Useign a varible
    By flowerrobot in forum AutoLISP, Visual LISP & DCL
    Last Post: 5th Apr 2009, 11:25 pm
  4. Public Health
    By GAZZA in forum MEP
    Last Post: 22nd Oct 2008, 12:10 pm
  5. The Joy of an E-Public life
    By Temporary Creature in forum Feedback
    Last Post: 2nd May 2006, 08:22 pm
