+ Reply to Thread
Results 1 to 4 of 4
  1. #1
    Full Member Goomba's Avatar
    Using
    Inventor 2010
    Join Date
    May 2010
    Posts
    41
    Default Weldment Table not showing mass correctly.
    I am trying to show the mass in the weldment cut list table for each item.
    If you go into the part and update the cut list and then look at the properties of the cut lists items the mass is correct in the cut list table.
    But when I bring the cut list onto the drawing it seems like all of the mass's have been divided by 8...
    Any ideas?
  2. #2
    Forum Deity shift1313's Avatar
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    thats odd goomba. How many of the item in question are there. Is it exactly by 8?
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  3. #3
    Using
    Inventor 2010
    Join Date
    May 2010
    Posts
    41
    Default
    Yeah it was exactly by 8 and it doesnt seem to happen to every weldment either..
    not sure... too hard basket, I just added another column and manually entered the masses
  4. #4
    Using
    not applicable
    Join Date
    Sep 2008
    Location
    VA
    Posts
    2,859
    Default
    sometimes you have to go back into the model and right click on the cutlist folder to update it. I cant imagine that would be the case here though. Without actually reproducing the problem im not sure where to start. is it a file you can share?
    www.mysolidbox.com
Similar Threads
  1. Excel table not printing correctly?
    By neuri in forum AutoCAD Beginners' Area
    Last Post: 5th Jul 2011, 03:31 am
  2. Xref with Images not showing correctly
    By feargt in forum AutoCAD General
    Last Post: 4th Aug 2009, 10:13 am
  3. Line type not showing correctly in model space
    By edwin in forum AutoCAD Beginners' Area
    Last Post: 11th Jul 2009, 03:27 am
  4. Drawing Border (Text not showing correctly)
    By Ste1978 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 28th Mar 2008, 05:57 pm
  5. plot style table not showing up in all drawings
    By BRENT in forum AutoCAD Drawing Management & Output
    Last Post: 4th Dec 2003, 07:09 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
