Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    Junior Member
    AutoCAD 2007
    May 2012
    17
    Okay sir, thanks!
  2. #12
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    Did you want to see a drawing using your example of a circle, polygon and rectangle each on a different layout?
    Just in case you came back and answered "yes" to my question. A simple example. Drawing was saved in 2000 file format so you should have no trouble opening it. Imperial units were used.
    CirclePolygonRectangle.dwg
  3. #13
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Quote Originally Posted by uekix View Post
    In the model space, i have 1 sheet and have 3 different drawing in it( lets say , i have a circle, a polygon, and a rectangle).
    How can i put the circle on Layout1 , the polygon on Layout2 and the rectangle on Layout3...
    Once you have your three layouts, create a viewport in each one with mview command. Then double click over the first viewport and open the layer manager. Scroll over to the right so you see VP Freeze column, check off two of the three layers so they will be frozen only in that viewport. Get out of that viewport, be sure to lock all of them, not necessary for this just a good idea to do. Now go to the next layout and repeat only freezing two layers that will leave a different one showing. Repeat for the last layout.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  4. #14
    Junior Member
    AutoCAD 2007
    May 2012
    17
    Thanks now i know , but why when i make a change to object in certain viewport, the other object in other viewport would have the same change? I did make the viewport with different layer , and i freeze the other layer when i make a change in certain viewport. It won't work.
  5. #15
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    You have to be specific about the type off change you are making. Are you freezing layers, modifying the objects, changing layer colors, just what are you referring to?
  6. #16
    Junior Member
    AutoCAD 2007
    May 2012
    17
    Yes i freeze the other layer so it wont get affected , i wanna modify the object like rotating it?
  7. #17
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    The viewport allows you to view the objects drawn in Model Space. If you draw a square on layer 1 there is only one object so if you rotate it, it will be rotated in any viewport where it shows.
    You have layer control over objects per viewport but not editing control.
    Maybe you can post an example of what you are trying to achieve.
  8. #18
    Junior Member
    AutoCAD 2007
    May 2012
    17
    Quote Originally Posted by rkent View Post
    So modifying object in certain viewport will surely affect the other viewport because they are using the same object.. so the only solution is changing the view of it (can rotate, etc) by using MVSETUP command ..anyway thanks!
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,127
    You could always make a copy of the object if you needed it for a special purpose.
  10. #20
    WIN7 PRO 64bit
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    Mechanical
    Mechanical 2014
    Nov 2007
    3,375
    Simply rotate the viewport, this works in newer releases.
    Also MVSETUP, DVIEW with TWist, or UCS and PLAN. May be others.
  1. Replies: 11
    Last Post: 19th Apr 2012, 11:16 pm
  2. How to make sectional view layout on paper space from 3D drawing?
    By Elcyclista in forum AutoCAD 3D Modelling & Rendering
    Last Post: 20th Dec 2011, 01:49 pm
  3. how to make 3d animation in autocad 2007
    By ranaumair in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Jun 2008, 10:52 am
  4. How to make power transmission chain in 3D in Autocad 2007
    Last Post: 8th Jun 2008, 02:50 pm
  5. how to make a gloves in 3D autoCAD 2007
    By alessandro754 in forum AutoCAD Drawing Management & Output
    Last Post: 21st Nov 2006, 11:19 am
