Diesel Posted May 9, 2012 Share Posted May 9, 2012 How do you name a viewport in the drawing. Thanks Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 9, 2012 Share Posted May 9, 2012 Not sure that understand your question – are you talking about terminology or want to assign it an Id to be able to access it later? Quote Link to comment Share on other sites More sharing options...
Diesel Posted May 9, 2012 Author Share Posted May 9, 2012 There is a way to make a view port and give the view port a name/ title... Just wondering how to do this... Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 9, 2012 Share Posted May 9, 2012 You may just add a text label close to the viewport (above or below); after call the GROUP command and join them together. May also use BLOCK command, but this will not allow you to adjust later the viewport. Quote Link to comment Share on other sites More sharing options...
Diesel Posted May 9, 2012 Author Share Posted May 9, 2012 From what I am reading there is a way to name a viewport for Sheet Set Manger. Quote Link to comment Share on other sites More sharing options...
Squirltech Posted May 9, 2012 Share Posted May 9, 2012 I think the user is wanting to use a "named viewport". I don't personally do this so I'm not sure how to do it. Quote Link to comment Share on other sites More sharing options...
MSasu Posted May 9, 2012 Share Posted May 9, 2012 I understand the mater now. Unfortunately I’m not able either to help OP on this. Just hope that someone with experience on this will notice the thread soon. Quote Link to comment Share on other sites More sharing options...
Diesel Posted May 9, 2012 Author Share Posted May 9, 2012 I think I figured it out. Here's the link http://cadtips.cadalyst.com/named-views/create-named-views-paper-space-viewports Thanks Quote Link to comment Share on other sites More sharing options...
CyberAngel Posted May 9, 2012 Share Posted May 9, 2012 What the OP may be thinking of is a named view, which can be associated with a viewport. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 10, 2012 Share Posted May 10, 2012 What the OP may be thinking of is a named view, which can be associated with a viewport. Bingo Cyber Angel, and that tip should sort the OP out, I just posted an addendum to it at the link. There are also NAMED VIEWPORTS which can be configured in the VIEWPORTS DIALOG and include 2D or 3D, visual style, etc. I think those are more for saving favorite configurations and styles, I usually use the VIEW MANAGER. Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 10, 2012 Share Posted May 10, 2012 Here is another good link regarding this sort of use of VIEWS, http://cadtips.cadalyst.com/named-views/synchronize-views-with-layer-state-manager-including-sheet-set-manager . Quote Link to comment Share on other sites More sharing options...
