+ Reply to Thread
Results 1 to 9 of 9
  1. #1
    Senior Member
    Using
    AutoCAD 2008
    Join Date
    Aug 2007
    Location
    North Wales
    Posts
    173
    Smile Drawing a spiral staircase
    Hello peeps, im trying to draw some stairs but really struggling in even finding a place to start. Basically I have a large cylinder which an access platform, I need to put some stairs to it as per the as fitted drawing which is lacking in info to say the least. I know the diameter of the tank, and the length of the stairs as the leave the platfor to the ground. I also know the floor elevation height, just not got a clue where to start.
    Forgot to mention the angine of the spiral staircase in 40degrees
    Any help would be most appreciated
  2. #2
    Senior Member
    Using
    AutoCAD 2008
    Join Date
    Aug 2007
    Location
    North Wales
    Posts
    173
    Default
    angine = angle
  3. #3
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,131
    Default
    The Architectural desktop and Revit both include a Stair Tool which can create spiral stairs.
    Do you have any guidelines at all?
    OK we got the angle, that is a start.
    What are they made of?
    Volume and repetition do not validate opinions forged in the absence of thought.
  4. #4
    Computer Details
    ReMark's Computer Details
    Operating System:
    Windows 7 Pro 64-bit
    Computer:
    Thinkmate
    Motherboard:
    Intel DX58SO2 LGA1366 X58
    CPU:
    RAM:
    12GB (3x4GB) PC3-106000 DDR3
    Graphics:
    nVidia Quadro 4000, 2GB GDDR5
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    ReMark's Discipline Details
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,026
    Default
    Post all the information you have so we know what parameters you are working with. Example: tank diameter, height of tank, width and depth of stair tread, height of riser, etc.
    If the spiral stairs are for a tank, unless this is a winery, they are most likely made of steel.
    I'm assuming you, Raj, would tell us if you were using a program other than AutoCAD to create the stairs in.
    You could work out the spacing of the stairs in 2D until you arrive at a solution that best fits what you know then take what you gain from that and create a 3D representation.
  5. #5
    Computer Details
    Operating System:
    Computer:
    Thinkmate
    Motherboard:
    CPU:
    RAM:
    Graphics:
    Primary Storage:
    Secondary Storage:
    none
    Monitor:
    Discipline
    See details...
    Occupation
    Discipline
    See details below.
    Details
    Using
    AutoCAD 2013
    Join Date
    Nov 2005
    Location
    Norwalk, CT USofA
    Posts
    33,026
    Default
    Is this similar to what you are attempting to create?
  6. #6
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,780
    Default
    spiral stair.jpgA house sprial staircase its easy but only to suit a fixed template. You create a 2d/3d stair tread insert it at a point rotate it and move it vertically the only tricky bit was the spiral hand rail but this was solved pretty easy by using a rotated ucs based on 3 pts cen st pt of rail end pt of rail these must be in 3d, used to wow clients had a lisp to just splat it in place. Will try to find image. The same idea can be applied to Remarks good example.
  7. #7
    Super Member stevsmith's Avatar
    Computer Details
    stevsmith's Computer Details
    Operating System:
    Windows 7 (64bit)
    Computer:
    Dell Precision T3500
    CPU:
    Intel Xeon W3670 (Six Core 3.2GHz, 12MB Cache)
    RAM:
    12 Gb Ram (3x4GB) DDR3
    Graphics:
    2GB NviDia Quadro 4000
    Monitor:
    BenQ G2020HD
    Discipline
    Electro/Mech
    stevsmith's Discipline Details
    Occupation
    Design Draughtsman
    Discipline
    Electro/Mech
    Details
    Hydrogen & Nitrogen Generator Development (LCMS & GC) Product Development Sheet Metal
    Using
    not applicable
    Join Date
    Apr 2008
    Location
    Largs, Scotland
    Posts
    918
  8. #8
    Full Member
    Computer Details
    rwhitt0724's Computer Details
    Operating System:
    Windows 7
    Discipline
    See details...
    rwhitt0724's Discipline Details
    Occupation
    Steel Detailer @ Misc. Fab Shop
    Discipline
    See details below.
    Details
    Steel Detailer Miscellaneous Items; Stairs, Railings, Nozzles, Platforms, Spiral Stairs, etc.
    Using
    AutoCAD 2011
    Join Date
    Oct 2009
    Posts
    53
    Default
    This is old obviously but I was searching spiral stairs. I can't generate you a 3D spiral stair but if you need one detailed, I'm your guy. lol
  9. #9
    Luminous Being JD Mather's Avatar
    Using
    Inventor 2013
    Join Date
    Sep 2007
    Location
    Williamsport, PA
    Posts
    6,904
    Default
    The Helix command will be your friend.
    Certified SolidWorks Professional
    Autodesk Inventor 2013 Certified Professional
    Autodesk AutoCAD 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
Similar Threads
  1. spiral base for spiral staircase
    By student86 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 31st Mar 2009, 04:48 pm
  2. Spiral staircase.
    By Mr T in forum AutoCAD General
    Last Post: 6th Feb 2009, 08:13 am
  3. How do I create a 3D spiral staircase?
    By zayarmt in forum AutoCAD 3D Modelling & Rendering
    Last Post: 22nd Jul 2008, 12:19 pm
  4. creating a spiral staircase
    By bernsky in forum AutoCAD 3D Modelling & Rendering
    Last Post: 30th Mar 2007, 11:03 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
