Results 1 to 5 of 5
    Full Member
    not applicable
    Mar 2012
    46
    Default Visio like connection (glue) points?
    Hi,
    I'm working on a lighting plan. So I want to create symbols for switches and for lights and connect a switch to a light using an arc so that when I move either switch/light, the arc is repositioned accordingly. Similar to connectors in visio.
    What is the method for doing that?
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    Please try if STRETCH command is helping you.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Inventor 2013
    Sep 2007
    Williamsport, PA
    6,906
    Geometric constraints on the Parametric tab.
    Autodesk Inventor 2013 Certified Professional
    http://home.pct.edu/~jmather/content..._Tutorials.htm
    Senior Member troggarf's Avatar
    troggarf's Computer Details
    Windows 7
    Toshiba Satellite L675
    AutoCAD 2012
    Oct 2010
    Littleton, Co
    130
    As mentioned, the stretch command would be useful.
    The link below demonstrates how to use it both at orthogonal angles (straight up or down) or at an angle
    How to use STRETCH:
    http://autocadtips.wordpress.com/201...o-use-stretch/
    How to use STRETCH at an angle:
    http://autocadtips.wordpress.com/201...with-an-angle/
    ~Greg B
    Have fun!! www
  5. #5
    Senior Member Blackfish's Avatar
    AutoCAD LT 2012
    Apr 2012
    182
    Similar solution to geometric constraints is to use a dynamic block with 2 no. Point Parameters (one for light and second for switch) and 2 no. Stretch Actions (one selection for light with one end of arc and second selection for switch with second end of arc).
  1. Replies: 4
    Last Post: 9th Aug 2011, 02:58 pm
  2. Visio
    By Wozza in forum AutoCAD Drawing Management & Output
    Last Post: 13th Feb 2009, 05:00 pm
  3. Glue Command
    By vicale345 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Dec 2006, 03:08 am
  4. Exporting to Visio
    By beavis123 in forum AutoCAD Drawing Management & Output
    Last Post: 10th Oct 2006, 12:03 pm
  5. Visio
    By xoom2 in forum Design Software
    Last Post: 7th Sep 2004, 02:06 pm
