+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 19 of 19
  1. #11
    Junior Member
    Computer Details
    MKearney028's Computer Details
    Operating System:
    Win 7 64-bit
    Computer:
    Dell Precision T3500
    CPU:
    Intel Xeon
    RAM:
    12GB
    Using
    Civil 3D 2012
    Join Date
    Sep 2010
    Location
    Wilmington, MA, USA
    Posts
    19
    Default
    I just ran across this same dilemma last week and found that routine from cadforum, and found that it didn't work. The other thing I found was the command "PSetupIn". Run it with (command ".-psetupin" "template location" "Template page setup") to insert a template page setup. I made a quick script of
    Code:
    (command ".-psetupin" "X:\\GPI CADD Settings\\New Drawing Template\\Plan Production\\Old MassDOT Title Block.dwt" "24x36 OcePW300")
    (foreach lay (layoutlist)(setvar "CTAB" lay)(command "._-plot" "_N" "" "24x36 OcePW300" "MA1 - OcePW300.pc3" "_N" "_Y" "_N"))
    and ran it through 330 layouts in about 10 minutes. Worked great.
    "If you steal from one author it's plagiarism. If you steal from many it's research." - Wilson Mizner
    That being said, always give credit where credit is due.
  2. #12
    Super Member
    Computer Details
    woodman78's Computer Details
    Operating System:
    Win XP
    Computer:
    Dell GX280
    Discipline
    Transport
    woodman78's Discipline Details
    Occupation
    Road Design Engineer
    Discipline
    Transport
    Details
    I work in a local authority design office with a staff of 13. We carry out road schemes ranging from overlays up to 2 km long new schemes.
    Using
    Civil 3D 2011
    Join Date
    Jul 2009
    Location
    Ireland
    Posts
    675
    Default
    You have 330 layouts in a single drawing????? Ah just saw your PC spec. Now it makes sense!!
  3. #13
    Junior Member
    Computer Details
    Operating System:
    Win 7 64-bit
    Computer:
    CPU:
    Intel Xeon
    RAM:
    12GB
    Using
    Civil 3D 2012
    Join Date
    Sep 2010
    Location
    Wilmington, MA, USA
    Posts
    19
    Default
    They were actually in a few drawings, most had 20 layouts or so and one had 127 layouts. I started by using Autoscript by Caddig, but with other people in some of the files, it was just as easy to open the files myself when I got to it and run the script.
    (And I forgot that my PC specs needed to be updated. )
  4. #14
    Super Member irneb's Avatar
    Computer Details
    irneb's Computer Details
    Operating System:
    Win7 Pro 64bit
    Computer:
    Antec One Hundred
    Motherboard:
    ASUS P8P67-Pro P67
    CPU:
    Intel i7 2600 @ 3.4GHz
    RAM:
    16GB-1600MHz
    Graphics:
    GeForce GT 430 (1GB)
    Primary Storage:
    Seagate1TB SATA2 - 7200rpm
    Monitor:
    Samsung 2333TN 23" 1920 x 1080 Full HD LCD Monitor2GW
    Discipline
    Architectural
    irneb's Discipline Details
    Occupation
    Architectural Technician and Programmer
    Discipline
    Architectural
    Using
    AutoCAD 2013
    Join Date
    Sep 2010
    Location
    Jo'burg SA
    Posts
    1,631
    Default
    One of my old routines: http://forums.augi.com/showthread.ph...-Setup-Manager
    About the FieldEval setting: That helps, but be careful about nested fields, e.g. say you've got a field extracting an area, then another copying that text and concatenating it with something else. No matter what the FieldEval is set to you might find one updating correctly, but not the other. For this reason I try to steer clear of such fields, not always possible though!
    Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
    My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
  5. #15
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,780
    Default
    heres another example plots all but not model
    http://www.cadtutor.net/forum/showth...=Printing-LISP
  6. #16
    Super Member
    Computer Details
    Operating System:
    Win XP
    Computer:
    Dell GX280
    Discipline
    Transport
    Occupation
    Discipline
    Transport
    Details
    Using
    Civil 3D 2011
    Join Date
    Jul 2009
    Location
    Ireland
    Posts
    675
    Default
    Bigal, the link doesn't work!
  7. #17
    Forum Deity pBe's Avatar
    Computer Details
    pBe's Computer Details
    Operating System:
    Windows XP
    Discipline
    Construction
    pBe's Discipline Details
    Discipline
    Construction
    Details
    Camp Construction planning and details
    Using
    AutoCAD 2009
    Join Date
    Apr 2010
    Posts
    2,089
    Default
    ----> Bigals Link
    BTW: Are you taking another route? Thought you want to stick with PUBLISH?
  8. #18
    Forum Deity
    Using
    Civil 3D 2013
    Join Date
    Dec 2005
    Location
    GEELONG AUSTRALIA
    Posts
    3,780
    Default
    Thanks pBe cut and pasted wrong
  9. #19
    Super Member
    Computer Details
    Operating System:
    Win XP
    Computer:
    Dell GX280
    Discipline
    Transport
    Occupation
    Discipline
    Transport
    Details
    Using
    Civil 3D 2011
    Join Date
    Jul 2009
    Location
    Ireland
    Posts
    675
    Default
    Hi pBe, I am sticking with publish for printing hard copies of drawings. But for multi printing pdf's I need something else. I have tried the pdfexport facility but i think it leaves a lot to be desired really and I can't get it to print the drawing to scale properly.
Similar Threads
  1. lisp to create layer and invoke colour picker
    By woodman78 in forum AutoLISP, Visual LISP & DCL
    Last Post: 8th Jun 2011, 01:51 pm
  2. "vlax-invoke" and "vlax-invoke-method"
    By muthu123 in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th May 2010, 01:18 pm
  3. add publish command to FAQ
    By chelsea1307 in forum Feedback
    Last Post: 14th Jan 2009, 09:32 am
  4. Publish command?
    By Jadgpanther in forum AutoCAD Beginners' Area
    Last Post: 25th Sep 2007, 06:39 pm
  5. X-Refs and Publish command....
    By StykFacE in forum AutoCAD Drawing Management & Output
    Last Post: 12th Sep 2006, 09:50 pm
Posting Permissions
  • You may not post replies
  • You may not edit your posts
