Page 1 of 4 1 2 3 ... LastLast
Results 1 to 10 of 37
    Full Member
    AutoCAD 2007
    Jan 2012
    26
    Default Measuring an existing drawing
    Hi everyone I have been provided an existing cad drawing as part of a project. I need to be able to measure the walls and interior of the drawing and I have the drawing set to mm. I would like to know what settings I need to change so that the measurements appear in mm as at the moment they arent. I have attached a picture to show the sort of measurements I am getting... is this something to do with scaling? The number on drawing is 15.700. Any help appreciated.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,004
    To validate that size try to use the DIST command - this will give the exact length between those points. If the value shown by dimension is different, then check the dimension style to don't have a multiplication factor different than one (Primary Units --> Scale factor).
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Full Member
    AutoCAD 2007
    Jan 2012
    26
    Many thanks for the response, I carried out the dist command that you have mentioned and it is giving the same figures.
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,004
    You're welcome!
    So, this means without doubt that that part is wrong drawn - if the size listed is different than the one that should be. Not sure what reside above items shown on your screen-shot, but please check if the STRETCH command can help you to fix the issue.
    Regards,
    Mircea
  5. #5
    Full Member
    AutoCAD 2007
    Jan 2012
    26
    it is the same for the whole drawing, if I change the units to millimetres, meters etc it still shows the same value. For example I drew a line and it measured 160, I then changed from meters back to millimetres and when I measured again it was still the same value. Ill expand on the problem a little bit...
    basically I have been given building plan that I need to work out heat loss calculations for, I need to get the dimensions of all walls etc.. I need to be able to convert the dimensions or distances so that they show in mm or cm, if possible I could provide the file for part of this drawing. Many thanks.
  6. #6
    Super Member Dana W's Avatar
    Dana W's Computer Details
    Windows 8 64 bit
    Dell XPS ONE 2710
    Dunno
    Intel I-5 3330S @ 2.7 Ghz
    6 Gb
    On board barely adequate
    1 Terrabyte
    1 Terrabyte external
    All in one 27" touch & pen
    Construction
    Dana W's Discipline Details
    Independent Architectural Draftsman
    Construction
    Residential Homes, Construction and Renovation
    AutoCAD LT 2009
    Feb 2010
    Chuluota, Florida
    1,770
    Did you establish which system of measurement and what insertion units the drawing was originally drawn in? Whatever it is/was is the measurement system and units value you need to use in your insertion units and your dimension styles.
    If you change the units after the fact, you will have to scale the entire drawing by the conversion factor (ratio) between the two units. However, you need to know what the original units were.
    You can also set your dimension style up so that it will display the primary units value, which should be the same as your insertion units, and a secondary units value at the same time. For instance, a dimension will be able to display imperial feet and inches, and milimeters on the same dimension line, or any other two measurement systems you might need.
    You should post a copy of the drawing here with proprietry information like company, property owner and address, and the like erased.
    Yogi Berra: "In theory there is no difference between theory and practice. In practice there is."
  7. #7
    Forum Deity Dadgad's Avatar
    AutoCAD 2012
    Nov 2011
    3,134
    Welcome to the forum.
    If you enter UNITS at the commandline the DRAWING UNITS dialog box will be opened, and if your drawing was done correctly you will find the INSERTION SCALE, which would tell you what UNITS are being called out by the distance command.
    The issue you are dealing with is the reason that ALTERNATE UNITS exist in the DIMENSION STYLE.
    The attached image shows a METRIC dimension style displaying MMs with the ALTERNATE UNITS set to also display IMPERIAL decimal style measurements below the dimension line.
  8. #8
    Full Member
    AutoCAD 2007
    Jan 2012
    26
    Hmm, I shall post part of the drawing. Perhaps I am missing something quite simple. Thanks for responses so far.
    plan.dwg
  9. #9
    AutoCAD 2012
    Nov 2011
    3,134
    Your drawing has been done on a METRIC template, as evidenced by the default scale list.
    The standard dimension style is displaying in feet and inches, and there is an alternate unit set up in the dimension style which displays the measurement in feet, followed by the metric measurement in milliimeters.
    If you explode the block, you can see details.
    Make a copy before you explode it, in case you need the block.
    I don't do architectural, but I would say that if the creator works in Imperial dimensions that the template chosen should have been an IMPERIAL biased one, instead of a METRIC one.
    Nonetheless, it all works.
    The insertion scale is set to MILLIMETERS, which seems strange, but I believe, correctly so, in light of the fact that the drawing has been done on a metric template.
  10. #10
    Full Member
    AutoCAD 2007
    Jan 2012
    26
    Thanks Dadgad, Where you say the metric measurement follows in MM, where is that? For example on another drawing in the safe format there is a lift shaft and in the above format the dimensions would be 2'-0 1/2" [622.301] x 1'-4 11/16" [424.48], if that is mm in brackets it sounds way too small.
  1. Insert into existing drawing
    By M76 in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Nov 2010, 04:23 pm
  2. Problem with drawing over existing drawing
    By steve 'o' in forum AutoCAD Beginners' Area
    Last Post: 3rd Sep 2009, 04:41 pm
  3. Gauge for Measuring Existing Wall Thickness
    By willwould in forum Catch All
    Last Post: 14th Jul 2009, 01:17 pm
  4. Using an existing drawing.
    By legend in forum AutoCAD Beginners' Area
    Last Post: 30th Dec 2007, 05:32 pm
  5. Creating a new drawing form an existing drawing -AC2002-
    By Michael in forum AutoCAD Beginners' Area
    Last Post: 16th Apr 2003, 07:41 pm
