Results 1 to 4 of 4
    Full Member
    AutoCAD 2010
    Nov 2011
    27
    Default CAD Standards Question
    I will be rolling out our new company wide standards this week. I'm looking for the easiest way to get all the LSP and SCR to run on everyones computer. What's the easiest way to do this without physically going to everyone's machine and doing it manually?
    Forum Newbie
    Civil 3D 2012
    May 2012
    7
    I'm sure there are many opinions out there, so don't just run with mine, but here's my suggestion:
    Add a restricted access network folder (a folder on your network to which only you and your crew have write-access, but everyone can read) to the top of the Support File Search Path list. (ex. S:\CAD\Support)
    Copy all your files into that folder.
    Create files in that folder called "acad.lsp" and "acaddoc.lsp"
    The acad.lsp file will run every time the program is initiated. (Figure maybe once per day)
    The acaddoc.lsp file will run everytime your users open a dwg. (Multiple times per session, even read-only)
    Figure out which routines need to load with which file. (You may not need both, depending on your situation)
    Cross your fingers and hope all your routines work (or you'll hear about it loudly, clearly, quickly and repeatedly)
    Super Member Pablo Ferral's Avatar
    Inventor 2010
    Feb 2005
    London
    577
    My favourite is to include them in the company CUI. Another way is to load a file from the server using the user's ACAD.lsp. You can re-write the server file any time you have a new LSP to load.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,588
    I'll back JRauch: creating and utilizing an ACADDOC.LSP file is what you're after. Autodesk covers this topic in their help file: http://exchange.autodesk.com/autocad...30d6b-7f7f.htm
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  1. Dimension standards question (annotative dims)
    By RingSteel in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Apr 2008, 04:45 pm
  2. cad standards
    By chrisdarmanin in forum AutoCAD Drawing Management & Output
    Last Post: 6th Feb 2008, 06:04 pm
  3. CAD Standards in the U.K
    By Tin in forum AutoCAD Drawing Management & Output
    Last Post: 2nd Oct 2007, 11:47 pm
  4. Standards
    By chulse in forum CAD Management
    Last Post: 25th Jul 2007, 09:41 pm
  5. Cad Standards
    By Cad Sponge in forum AutoCAD Drawing Management & Output
    Last Post: 25th Jul 2007, 01:03 am
