Results 1 to 7 of 7
    Full Member nila_joy's Avatar
    nila_joy's Computer Details
    Windows
    Mechanical
    nila_joy's Discipline Details
    Design Engineer
    Mechanical
    working on various tools like cad, Pro-E, Lisp , VB. Working on automation department.
    AutoCAD 2011
    Nov 2011
    Kolkata, India
    26
    Default want to change linetype color manually ..
    Hi guys.. I AM BACK ..
    I want to change all linetype color manually for printing purpose . Means I want to change all the hidden line of a drawing in red, all continuous in brown ..like this. Now the problem is ..
    1. The code for the linetype is 6 , but whenever the line type is dedicated for a layer, the code 6 is not showing, then how I'll get all the hidden line types (may be in different layers) of a drawing ..
    2. From table search I can get all the line type available in the drawing, but all those line types are in used? I am in doubt .. I failed to find them visually in my drawing ..
    3. I can get the layer name from DXF code 8 , but how can I get the details of the layer, like color, line type etc ..
    Plz help guys ...
    Subho..
    KOlkata..
    India ..
    Lee Mac's Computer Details
    Win 7 Pro / Win 10 Pro / Linux Mint
    Multi-disciplinary
    Lee Mac's Discipline Details
    Multi-disciplinary
    AutoCAD 2018
    Aug 2008
    London, England
    19,539
    Maybe you can learn from this example:
    Code:
    (defun c:getlinetype ( / dxfdata entity )
        (if (setq entity (car (entsel)))
                (setq dxfdata (entget entity))
                (cond
                    (   (cdr (assoc 6 dxfdata)))
                    (   (cdr (assoc 6 (tblsearch "LAYER" (cdr (assoc 8 dxfdata))))))
    Lee Mac ProgrammingTwitterExchange App StoreDropbox (500MB free)
    Windows
    Mechanical
    Design Engineer
    Mechanical
    AutoCAD 2011
    Nov 2011
    Kolkata, India
    26
    Thnx lee.. thnx a lot ..
    waiting for others reply ...
    Luminous Being Tharwat's Avatar
    Mechanical
    Tharwat's Discipline Details
    MEP AutoCAD Draughtsman
    Mechanical
    HVAC, Drainage, Water Supply, Fire Fighting and a little about Electricity.
    AutoCAD 2015
    Oct 2009
    Great Syria , Living in Abu Dhabi
    6,178
    Can you please explain what you looking for straight to the point ?
  5. #5
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Quote Originally Posted by nila_joy View Post
    There can be 3 cases:
    1. Linetypes attached directly to entities:
    Code:
    (ssget "_X" '((6 . "DOT")))
    2. Linetypes attached by layers - need to check which layers have a linetype other than Continuous; check if those layers are empty or not:
    Code:
    (ssget "_X" (list (cons 8 LayerWithDottedLine)))
    3. Linetypes attached directly to entities inside blocks, a little harder to parse.
    This is for programmatically approach; to visually inspect this just call the PURGE command and check if there are linetypes proposed for remove.
    To see layer's properties check his record using TBLSEARCH:
    Code:
    (entget (tblsearch "LAYER" "0"))
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  6. #6
    Windows
    Mechanical
    Design Engineer
    Mechanical
    AutoCAD 2011
    Nov 2011
    Kolkata, India
    26
    ok, let me explain plainly .. I want to change the colors of the lines of a drawing for printing purpose .. I am writing a program in which all the line types of the drawing will be shown as a list (using DCL) in the left side, and in the right side color box will be shown (already made it by using image DCL) .. user will select one line type from left (like hidden) , assign a color from right (like red) .. and all the hidden lines of the drawing (may be not in same layer ) will be change into red.
    hope I explained what exactly I want to do ..
    Subho..
    Kolkata..
    India ..
  7. #7
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    4,008
    Above you have most of the information to list entities by their linetype. To change the color, check the SUBST and ENTMOD functions too.
    The color is stored under DXF code 62, except when is attached per container layer and this code isn’t available. You will have to treat those cases differently.
    I suggest you to start to design the part to gather entities by their linetype and post your attempt here for debug.
    Regards,
    Mircea
  1. Replies: 11
    Last Post: 16th Oct 2012, 03:33 pm
  2. Change Bylayer ( color,lineweight,linetype )
    By vnanhvu in forum AutoLISP, Visual LISP & DCL
    Last Post: 17th Aug 2011, 05:14 pm
  3. Replies: 4
    Last Post: 18th Jan 2011, 12:06 am
  4. Is it possible to change the color of a linetype?
    By Proctor in forum AutoLISP, Visual LISP & DCL
    Last Post: 4th Mar 2010, 12:04 am
  5. Lisp to change all objects with a certain color to another color
    By mikeSIEMENS in forum AutoLISP, Visual LISP & DCL
    Last Post: 15th Jan 2010, 04:59 pm
