Trying to print multiple drawings. I setup up the first sheet then publish command. I select all the drawings and change the page setup and they all change to the first sheet. Then I press publish and only the first sheet goes. What am I doing wrong? I went through a tutorial on You Tube and did everything but result is the same, only the first sheet.
In the options dialog, turn off the background publish in the Plot tab. The background does strange things with batch plots.
Knowledge is proportional to experience, but wisdom is inversely proportional to ego!
My little bit of "wisdom": Hind-sight is useless, unless used to improve the next forethought!
