Diesel Posted May 15, 2012 Share Posted May 15, 2012 (edited) Now that I have all my custom properties set up I can't seem to update the custom ones that I made. The custom properties I have added do not seem to work when I update them the through the Sheet Set Manger properties. Any Thoughts Thanks Edited May 15, 2012 by Diesel Quote Link to comment Share on other sites More sharing options...
Blackfish Posted May 15, 2012 Share Posted May 15, 2012 Do you mean in your sheet set or in your layouts/drawings? Quote Link to comment Share on other sites More sharing options...
Diesel Posted May 15, 2012 Author Share Posted May 15, 2012 Yes I am having to delete them and add them back in order to get them to work... Quote Link to comment Share on other sites More sharing options...
Blackfish Posted May 15, 2012 Share Posted May 15, 2012 You click 'Edit Custom Properties', don't you? And then there is no way to edit them... because this button is only to add/delete your properties. To change a default value you should edit them straight in the table when you click 'Properties' of your sheet set, the same table, where you see the 'Edit Custom Properties' button. Just click on the field you would like to change. Quote Link to comment Share on other sites More sharing options...
Diesel Posted May 15, 2012 Author Share Posted May 15, 2012 I do that but the custom properties do not update, they go back to what was in them before. Quote Link to comment Share on other sites More sharing options...
Blackfish Posted May 15, 2012 Share Posted May 15, 2012 (edited) UPDATEFIELD command And check the following link: http://usa.autodesk.com/autocad-lt/training/#sheet Edited May 15, 2012 by Blackfish Quote Link to comment Share on other sites More sharing options...
