Results 1 to 3 of 3
    Junior Member
    AutoCAD 2010
    Feb 2012
    10
    Default Associative Dimension Problems in Paper Space
    I created several dimension styles to use in paper space. All of these work perfectly, and accurately if my dimassoc is set a 1. However I wanted these to be associative dimensions. When I change the dimassoc to 2, the associative dimensions aspect of this works, but the dimension text is multiplied by the scale factor for some reason. For example, the dimensions should read 50' and now read 4800' when was scale factor is at 96 for 1/8" scale. How do I go about setting up my dimstyle to be assocaitive and accurate? Typically I have several different scale viewports on each sheet in paper space, so I need multiple dimension styles. Any help would be great. Thanks.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,024
    Why would you need several dimension STYLES?
    Making dimensions associative should have no bearing on the scale of your dimension text.
    Senior Member Blackfish's Avatar
    AutoCAD LT 2012
    Apr 2012
    182
    If you measure the distance of 50' in paper space in layout with scale of 1/8" your 4800' is right, because Autocad multiply it by 96 to get the real size of element drawn in model space. However you can change it and set "Dim scale linear" in Propertis from 96 into 1.
    PS. What is interesting Autocad measure blocks with not equal scale (x, y or z) as they were drawn in paper space!
  1. LTSCALE - Model Space/Paper Space Differences and problems
    By Fedge in forum AutoCAD Drawing Management & Output
    Last Post: 15th Nov 2011, 02:33 pm
  2. How to Freeze paper space dimension layer in model space
    By david1954 in forum AutoCAD 3D Modelling & Rendering
    Last Post: 13th May 2010, 04:16 pm
  3. dimension paper space problems
    By b.muqlueen in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 12th Aug 2008, 12:57 pm
  4. Dimension in paper space
    By AutoCAD Tips Blog in forum AutoCAD RSS Feeds
    Last Post: 28th Oct 2006, 10:00 pm
