Results 1 to 3 of 3
    Super Member
    Architectural DT 2007
    Dec 2002
    London
    1,087
    Default Poor Revit walkthroughs and memory usage
    I've been trying again and again with this feature in Revit and each PC I've used starts to run out of memory (16GB).The walkthroughs are set up, defined the path checked all the keyframes,but the final part just seems useless if you want a decent rendered walkthrough.Ive tried lots of settings such as:
    Changing the frames a second from 20 up to 30/sec
    Changing the total frames from 300 up to 900
    Changing the speed of the frames from 1 to 0.1
    Also if export the walkthrough using shaded with edges, all the edges just distort in the avi file,no matter what setting I check.
    To be honest I've almost given up with Revit for walkthroughs and am looking to possibly use 3D Max.Is there anything I should try before going the 3D Max route?
    Super Member RobDraw's Avatar
    AutoCAD 2011
    Apr 2007
    Connecticut, USA
    1,239
    I haven't used walkthroughs but I'm pretty sure the changes you mentioned will increase memory usage. Shouldn't you be decreasing those settings in order to use less memory?
    Rob
    Senior Member Lee Roy's Avatar
    Lee Roy's Computer Details
    Windows 7 Professional 64-bit
    HP Z400
    Intel Xeon W 3565 @ 3.2GHz
    16GB
    ATI FirePro V5900
    OCZ Vertex 4 - 256GB - Sata III - SSD
    Seagate Barracuda 1TB 7200rpm
    Dual - HP Compaq LA2405wg
    Multi-disciplinary
    Lee Roy's Discipline Details
    CAD/BIM Manager
    Multi-disciplinary
    Architectural, Mechanical, Plumbing, Electrical...JOAT
    Revit 2014
    Apr 2011
    Visalia, CA
    417
    Quote Originally Posted by RobDraw View Post
    Yes.
    (10 character post limit)
    "The thing about quotes on the internet is that you cannot confirm their validity." - Abraham Lincoln
    I -edit- a lot, sorry.
    The rotary engine is the most efficient way of converting fuel to noise ever invented.
    If my post sounds offensive, but can be meant in a non-offensive manner...I meant the latter.
  1. AutoCAD Memory usage sky high
    By busseynova in forum AutoCAD General
    Last Post: 15th May 2012, 02:08 am
  2. Memory Usage Issue
    By vertical horizons in forum Autodesk Inventor
    Last Post: 29th Apr 2010, 05:26 pm
  3. Question about memory and peak memory
    By gbelous in forum Hardware & Operating Systems
    Last Post: 7th Apr 2010, 06:31 pm
  4. 3D Studio MAX WalkThroughs
    By ttiefenbach in forum AutoCAD 3D Modelling & Rendering
    Last Post: 23rd Oct 2007, 01:58 am
  5. Effricient Memory usage
    By superjari in forum AutoCAD Drawing Management & Output
    Last Post: 9th Feb 2003, 01:43 pm
