Results 1 to 2 of 2
    Forum Newbie
    Revit MEP 2011
    May 2012
    1
    Default Revit Window Glitch
    So I have Revit open with the split vertical viewport option on, but the program is only running in the left view. The right one which is set for 3D is just blank and whenever I try to select that side the 3D viewpops up on the 2D side and will act as if the whole screen is set to 3D. Any suggestions on how to fix this would be greatlyappreciated.
    Luminous Being StykFacE's Avatar
    StykFacE's Computer Details
    Windows 7 Ultimate 64bit
    Dell Precision T3500
    Multi-disciplinary
    StykFacE's Discipline Details
    BIM Manager & Design Specialist
    Multi-disciplinary
    Facilities engineering, involving mechanical piping, mechanical HVAC and electrical engineering.
    Revit 2013
    Mar 2006
    Dallas, TX - USA
    6,497
    You need to adjust your View Template, V/G, or View Range.
    Tannar Frampton | Facilities Engineering | Revit 2013
    Personal Projects | Fender Squier Stratocaster | Custom Smoker | Concrete Patio
  1. Glitch?
    By iamstd2 in forum AutoCAD Beginners' Area
    Last Post: 26th Jan 2012, 01:20 am
  2. 3D Dimensioning Glitch
    By Scroto_T_Baggins in forum AutoCAD Beginners' Area
    Last Post: 27th May 2011, 04:39 pm
  3. New Glitch in the Matrix
    By eklektikus in forum Hardware & Operating Systems
    Last Post: 7th Jan 2011, 03:10 pm
  4. Line glitch
    By lam2008 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 21st Oct 2010, 02:39 pm
  5. Glitch
    By AsbuiltEdge in forum AutoCAD Drawing Management & Output
    Last Post: 26th Jan 2006, 12:10 pm
