Page 2 of 10 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 96
Thread: Total noob
  1. #11
    Forum Deity
    nestly's Computer Details
    Windows 7 Pro (64bit)
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    It appears to me that you used an Imperial template to create drawing in metric units. Although not impossible to convert, it will be far easier to just open a new metric template and use the clipboard to copy/paste everything from your existing drawing into the new/blank template.
  2. #12
    Full Member
    AutoCAD 2013
    May 2012
    55
    A4 sheet (one floor plan per sheet) and i have no idea how to use view points
  3. #13
    Full Member
    AutoCAD 2013
    May 2012
    55
    how do i change the template to metric
  4. #14
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    To use a viewport in a paper space layout it helps to utilize the Page Setup Manager and select a paper size. After you have made your selection and have indicated any other choices you deem necessary you return to your layout and use the MVIEW command to create one or more viewports.
    Viewports should, in my opinion, go on their own layer and that layer should be set to "no print" in the Layer Properties Manager.
    Viewports have a scale assigned to them not the objects that exist over in model space (which should have been drawn to FULL size).
    Viewports can be resized using their grips.
    Viewports can be moved, copied, rotated and even deleted all without affecting model space objects.
    Once a viewport's display has been set, and you are happy with the scale, the display should be locked (via the Properties palette or some other means) to prevent accidentally changing the viewport scale inadvertently.
    Where were you planning on placing your dimensions and any text? In model space or in your layout?
  5. #15
    Full Member
    AutoCAD 2013
    May 2012
    55
    model space i have to give a floor plan with dimensions
  6. #16
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    * edit * removed pending clarification.....
  7. #17
    Full Member
    AutoCAD 2013
    May 2012
    55
    if u could tell me how to set up a template in which i draw using meters (metric) and the scaling will be accurate on the layout...so i can draw and have no problems with printing
  8. #18
    Full Member
    AutoCAD 2013
    May 2012
    55
    thanks nestly
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,878
    Quote Originally Posted by bothal08 View Post
    The best practice would be to use a feature called "Annotative Scaling" which can be applied to blocks, hatching, text and dimensions. You'll have to view a tutorial to understand how the feature works. If you are pressed for time or you have trouble understanding how to use this feature then you could put both your text and dimensions directly in your layout. I will not make a recommendation of one over the other because I think it is up to the user to try both and make their own decision. For the record, I do not use annotative scaling although I have tried it and I am somewhat conversant on the subject.
  10. #20
    Forum Deity
    AutoCAD 2015
    Sep 2010
    PA
    3,444
    Weird, when I opened your original drawing (2013) format, the drawing units were Architectural, but when I opened your 2nd one with AutoCAD2011, they're Decimal, so what I previously said about your drawing being Imperial may be erronious.
  1. My CAD noob question!
    By jeremyjjbrown in forum AutoCAD Beginners' Area
    Last Post: 27th Jan 2010, 09:36 pm
  2. Another noob
    By Mark1965 in forum AutoCAD Beginners' Area
    Last Post: 19th Jan 2008, 10:35 pm
  3. Even Noobs think I'm a Noob!
    By Jon GoTA in forum AutoCAD Beginners' Area
    Last Post: 18th Jun 2007, 11:17 am
  4. Total noob hoping to be an architect some day :)
    By Cool Like That in forum AutoCAD Beginners' Area
    Last Post: 8th Jun 2006, 02:16 pm
