Page 3 of 10 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 96
Thread: Total noob
  1. #21
    Full Member
    AutoCAD 2013
    May 2012
    55
    ok cool...after doing what nestly said...i click on layout 1 at the bottom and its all fitting on the page but bottom right it says 2.48 (view point scale) does that mean the print out will show the drawing to a scale of 1:2.48?? where do i see what the print scale will be??
  2. #22
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    First I would take care of the viewport scale before I start worrying over printing.
    The beauty of using a layout is that when you do go to print you do so at a scale of 1:1 (1 unit = 1mm). AutoCAD will automatically handle the printing of each viewport based upon the scale assigned to it. You don't have to do anything but sit back and let AutoCAD handle it.
    Yes, the viewport scale is displayed in the lower right hand corner of your screen. If you click on it you'll see a list of available scales (the user can add/delete scales). Choose a scale and see what happens.
  3. #23
    Full Member
    AutoCAD 2013
    May 2012
    55
    ok i see but how come when i click on scale 1:1 the drawing still fits on the page?
  4. #24
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    You probably did not draw it to full size in model space?
  5. #25
    Full Member
    AutoCAD 2013
    May 2012
    55
    ok so the units are decimal millimeters...and i have been typing in one unit for one meter but its acyually millimeters...but when i try draw a meter long line (1000) it shoots off the screen
    how do i draw to actuall size
  6. #26
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    1 unit can be equal to what ever you want, i.e. - 1mm, 1cm, 1m, 1km, etc. You should have given some thought to where the decimal point had to go when you typed in your distances.
  7. #27
    Full Member
    AutoCAD 2013
    May 2012
    55
    ok well i just used 1 unit = 1 meter....but its still so small on the layout (scale 1:1)
  8. #28
    Full Member
    AutoCAD 2013
    May 2012
    55
    the line just goes off the map and i cant zoom out any more
  9. #29
    Full Member
    AutoCAD 2013
    May 2012
    55
    FLOOR PLAN 2010.dwg
    this is what its like...just check the layout and scale
  10. #30
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,877
    I think everything you drew is to the left of 0,0 first of all. And second, you can always try a Zoom > All or a Zoom > Extents to find what you are looking for.
    OK...I just took a look at your drawing. As I suspected everything you drew is way off to the left of 0,0. And I notice that despite having four layers (not counting Defpoints which is created by AutoCAD) it appears you may have drawn everything on layer "0". Not a good practice. If you have a layer called Furniture with its own distinct color that is the layer your furniture should naturally go on and you should not override the color (it should be set to "By Layer") unless there is a good reason to do so.
  1. My CAD noob question!
    By jeremyjjbrown in forum AutoCAD Beginners' Area
    Last Post: 27th Jan 2010, 09:36 pm
  2. Another noob
    By Mark1965 in forum AutoCAD Beginners' Area
    Last Post: 19th Jan 2008, 10:35 pm
  3. Even Noobs think I'm a Noob!
    By Jon GoTA in forum AutoCAD Beginners' Area
    Last Post: 18th Jun 2007, 11:17 am
  4. Total noob hoping to be an architect some day :)
    By Cool Like That in forum AutoCAD Beginners' Area
    Last Post: 8th Jun 2006, 02:16 pm
