Insert Image without border?
D1-Xen
I would like to insert JPG image without a border.
AutoCAD > Insert > Raster Image Reference > ... find the file
Good, I got the file. But it has a border!? :glare:
I cannot seems to remove it regardless. I tried selecting the colour white, but the border is still there.
It will be good if that North Orientation did not have the line. Suggestion? Capture.PNG
Try the command IMAGEFRAME and set it to OFF.
You will not be able to move the image when the frame is turned off.
IMAGEFRAME > 0 (default = 1)
Problem solved. Thank you.
