luppolo Posted May 19, 2012 Share Posted May 19, 2012 Hi. I'm wondering if autocad 2012 allows to display a raster image while is moved. I mean the content of the image, not the frame only.... Thanks in advance... Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2012 Share Posted May 19, 2012 Welcome to Cad Tutor. I believe you want to consider this setting. RTDISPLAY > 0 Enter RTDISPLAY at the commandline and then change the value to 0. Quote Link to comment Share on other sites More sharing options...
luppolo Posted May 19, 2012 Author Share Posted May 19, 2012 Many Thanks. But it's not working in autocad 2012 (Autocad Map)..Both values allow to display the frame only! It seems to me this is reffered only to Realtime ZOOM and PAN..I need to see the image shile I'm moving it from a point to another.. Quote Link to comment Share on other sites More sharing options...
luppolo Posted May 19, 2012 Author Share Posted May 19, 2012 I mean "while I'm movig it". not "shile" Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 19, 2012 Share Posted May 19, 2012 Many Thanks.But it's not working in autocad 2012 (Autocad Map)..Both values allow to display the frame only! It seems to me this is reffered only to Realtime ZOOM and PAN..I need to see the image shile I'm moving it from a point to another.. Sorry that didn't help you. Here are all of the system variables which begin with RASTER, I looked at them, and don't believe that they will help you either. Quote Link to comment Share on other sites More sharing options...
luppolo Posted May 19, 2012 Author Share Posted May 19, 2012 Yes..I agree.. Thanks in any case.. I believe this option was avalible in older autocad versions...(but not so sure..!) Quote Link to comment Share on other sites More sharing options...
Blackfish Posted May 19, 2012 Share Posted May 19, 2012 Please read 'All About Images': http://www.cadtutor.net/tutorials/autocad/all-about-images.php At the end there is something about Tools -> Options... Maybe that's what you're looking for Quote Link to comment Share on other sites More sharing options...
luppolo Posted May 19, 2012 Author Share Posted May 19, 2012 Thanks Blackfish. I guessed your suggestion was what I'm looking fo,r but, unfortunateley, after deactivating the option "Higlight raster image frame only", the result doesn't change... While moving or rotating the image, the frame only is displayed... - Quote Link to comment Share on other sites More sharing options...
Blackfish Posted May 20, 2012 Share Posted May 20, 2012 (edited) I have tried it and you right... it's odd. However if you want to see an image while moving is to follow certain points in the image, I mean to know where to move the image or use as a refence with scale my solutions is to draw reference (control) points or line over the image and move, rotate or scale them together with the image. You will see all AutoCAD elements and the frame of the image. I hope it will help you Edited May 20, 2012 by Blackfish Quote Link to comment Share on other sites More sharing options...
luppolo Posted May 20, 2012 Author Share Posted May 20, 2012 Yes....This is the walking around I'm using.. Nevertheless, It's quite ridicolous Autocad doesn't let to display an image while you are scaling, moving or rotating it... It's also true that there are things worse than this in the life.. Thanks... Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 21, 2012 Share Posted May 21, 2012 Are you using vanilla AutoCAD or MAP3D? Quote Link to comment Share on other sites More sharing options...
luppolo Posted May 21, 2012 Author Share Posted May 21, 2012 Hi. I'm using MAP3D. Quote Link to comment Share on other sites More sharing options...
Emigrato Posted May 21, 2012 Share Posted May 21, 2012 (edited) O Luppolo, sei italiano? E' normale che tu non veda il contenuto dell'immagine mentre la sposti in tempo reale, proprio perche' Autocad non e' un editor raster, bensi' vettoriale... Edited May 22, 2012 by Emigrato Quote Link to comment Share on other sites More sharing options...
luppolo Posted May 22, 2012 Author Share Posted May 22, 2012 Emigrato, in effetti, quel che dici ha parecchio senso.. :-) Quote Link to comment Share on other sites More sharing options...
Emigrato Posted May 22, 2012 Share Posted May 22, 2012 Perchè non ti aggiungi al nostro gruppo Facebook di utenti italiani Autocad Map? Quote Link to comment Share on other sites More sharing options...
SLW210 Posted May 22, 2012 Share Posted May 22, 2012 We use English on this forum. Quote Link to comment Share on other sites More sharing options...
lioncub99 Posted November 15, 2012 Share Posted November 15, 2012 try imageframe this will help Quote Link to comment Share on other sites More sharing options...
Emigrato Posted November 16, 2012 Share Posted November 16, 2012 try imageframe this will help It doesn't matter, sir. My compatriot wants only to see the image content when dragging it, and none of Imageframe options allows that... Quote Link to comment Share on other sites More sharing options...
