Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    Forum Newbie
    AutoCAD not applicable
    May 2012
    7
    Default Renaming attributes tags according to a "master" drawing.
    Hi,
    I'm looking for a lisp to help me rename tags in a drawing according to another drawing.
    The values in the attributes should remain the same and it involves many different blocks so it can't be done manually.
    Thanks.
    Forum Deity pBe's Avatar
    pBe's Computer Details
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,015
    Welcome to the CADTutor Forum liormic.
    That sounds fun to code.
    Ttry this one first: -- > LM Batch Attribute Editor
    Forum Newbie
    May 2012
    7
    Thanks but it doesn't work.
    After selecting the blocks I get "Automation Error. No database" and it returns to the command prompt.
    I also didn't understand where exactly do I write the new tag name.
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,015
    Quote Originally Posted by liormic View Post
    My apologies liormic, I just blindly directed you to that particular lisp program. It does work on certain conditions. Perhaps look at the other codes for attributes on Lee Mac's website.
    LM may have an updated attribute function that deals with TAGS along
    If all else fails then we'll write one for you. or better yet,
  5. #5
    Forum Newbie
    May 2012
    7
    It's a great site LM has with many interesting things but I didn't find anything that deals with renaming the tag.
  6. #6
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,015
    I see, okay tell us what do you have in mind.
    Will it always be that drawing as source? or it differs for one drawing to another?
    Is that the source block or the target?
  7. #7
    Forum Newbie
    May 2012
    7
    The thing is that there's a drawing with a set of blocks and every once in a while I get another drawing with another set of blocks which I have to change the blocks in it so the tags would be the same every time.
    The values shouldn't be changed but the blocks's names, tags and layers should.
    I can manage changing manually the blocks's name and layers but not the tags.
    I think the best would be if it's possible to make some kind of a table with the block's name, layer and attribute's tags from 1 drawing to corraspond to another block's name, layer and attribute's tags from another drawing it would be the best.
    Thanks.
  8. #8
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,015
    The caped crusader can take care of that really. [commnad: Battman]
    But if you want a lips code. Give me a real time example and we'll wirte a code for that. I still don't get the "Master Drawing" factor though.
    You may have something there with that idea . I couldve have sworn i wrote a code similar to that some time ago.
  9. #9
    Forum Newbie
    May 2012
    7
    The Battman does the job but every time I need to go and change each block according to it's tags.
    The "master drawing" isn't important. It's just a drawing which has the new blocks. A list of old blocks and tags Vs. new ones should do.
    Thanks.
  10. #10
    Windows 8.1
    Landscape
    AutoCAD 2015
    Apr 2010
    3,015
    Thanks.
    Do you need a lisp routine? or are you telling us that is what you going to do? You can include the list within the lisp routine though [hardcoded], to eliminate the need to open/read an external file.
  1. drawing "by block" not "by layer"
    By DoctorDrake in forum AutoCAD General
    Last Post: 8th Mar 2012, 09:21 pm
  2. Automatically updating "defined width" attributes for MTEXT?
    By Comatosis in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 8th Dec 2011, 09:59 pm
  3. Help needed with "ssget filter for inserts with specific attribute tags"
    By MarcoW in forum AutoLISP, Visual LISP & DCL
    Last Post: 9th Jun 2011, 03:42 pm
  4. "Tags" w/ associative/interactive schedules
    By Cad Monkey 2 in forum Architecture & ADT
    Last Post: 25th Feb 2011, 10:18 pm
  5. Replies: 1
    Last Post: 25th Nov 2009, 06:35 pm
Tags for this Thread
