+ Reply to Thread
Results 1 to 2 of 2
  1. #1
    Full Member
    Discipline
    Electrical
    btraemoore's Discipline Details
    Occupation
    Electrical Designer
    Discipline
    Electrical
    Using
    Electrical 2012
    Join Date
    Apr 2012
    Location
    Houston
    Posts
    55
    Default having save-as problems from autocad to excel...
    Im trying to saveas the work ive done as a different file name, and i keep getting "script out of range" can some one throw me a bone?
    Code:
    ' Declare Working Directory
        Global Const WrkDir = "C:\Documents and Settings\moorerb\Desktop\asset worksheets\"
    ' Declare Excel Workbook name
        Global Const Master_WorkBook = WrkDir & "bptags.xls"
        Global Const Secondary_WorkBook = WrkDir & "mytemp.xls"
    ' Declare Excel Worksheet name
        Global Const Master_WorkSheet = "ccu3"
        Global Const Secondary_WorkSheet = "mytemp"
    Global workbooks As Object
    Global ExcelVer As Integer
    Global ExcelServer As Object
    Global ObjWorksheet As Object
    'Global SecWorksheet As Object
    'Global ObjWorkbook As Object
    Global FileSaveName As String
    ' end of global variables
    Sub RetrieveEXC()
        Set ExcelServer = CreateObject("Excel.Application.11")
            Set workbooks = ExcelServer.workbooks
            workbooks.Add ("C:\Documents and Settings\moorerb\Desktop\asset worksheets\mytemp.xls")
            workbooks.Open (Master_WorkBook)
        Set ObjWorksheet = ExcelServer.ActiveWorkbook.worksheets(Master_WorkSheet)
            'ExcelServer.WindowState = -4140
            ExcelServer.Visible = True
            FileSaveName = WrkDir & Dwg_Name & ".xls"
            'Set SecWorksheet = ExcelServer.ActiveWorkbook.worksheets(Secondary_WorkSheet)
                        the line below is where my issue lyes.
            workbooks(Master_WorkBook).Sheets(Secondary_WorkSheet).Move After:=workbooks(Secondary_WorkBook).Sheets(1)
            workbooks(Secondary_WorkBook).SaveAs FileSaveName, fileformat:=56
            set_to_null
            ActiveWorkbook.SaveAs FileName:= _
            FileSaveName, fileformat:= _
            xlNormal, Password:="", WriteResPassword:="", ReadOnlyRecommended:=False _
            , CreateBackup:=False
    End Sub
    these are my watches
    Watch : : Master_WorkBook : "C:\Documents and Settings\moorerb\Desktop\asset worksheets\bptags.xls" : String : Exwork
    Watch : : Master_WorkSheet : "ccu3" : String : Exwork
    Watch : : Secondary_WorkBook : "C:\Documents and Settings\moorerb\Desktop\asset worksheets\mytemp.xls" : String : Exwork
    Watch : : Secondary_WorkSheet : "template" : String : Exwork
    Watch : : FileSaveName : "C:\Documents and Settings\moorerb\Desktop\asset worksheets\B-4800-E-4419T.xls" : String : Exwork.RetrieveEXC
  2. #2
    Full Member
    Discipline
    Electrical
    Occupation
    Electrical Designer
    Discipline
    Electrical
    Using
    Electrical 2012
    Join Date
    Apr 2012
    Location
    Houston
    Posts
    55
    Default
    just to update, this is the working code
    Code:
    ' work done in excel
    Sub excelwork()
        Dim i As Integer, n As Long, c As Long
            c = 8
        Dim CurrentItem As String
        Dim pause As Boolean
        Dim match As Variant
        Dim NewSheetName As String
            NewSheetName = Dwg_Name & "assets"
        'set a count for items in collection
        For i = 1 To EOC
        Cur_TxtSTR = text_coll(i)
        MasWorksheet.Activate
        MasWorksheet.cells(1, 3).Activate
            'set a count for items in excel spreadsheet
            For n = 1 To 876
            CurrentItem = MasWorksheet.cells(n, 3).Value
                'compare collection item to each excel item, until we find our match
                If Cur_TxtSTR = CurrentItem Then
                    MasWorksheet.Rows(n).Select                ' select the row
                    MasWorksheet.Rows(n).Copy                  ' copy the row
                    secWorksheet.Activate
                    secWorksheet.cells(c, 1).Activate
                    secWorksheet.paste                         ' paste the row in the new sheet
                    secWorksheet.cells(c, 10).Value = Dwg_Name ' insert the drawing name in new sheet
                    c = c + 1
                End If
            Next n
        Next i
        secWorksheet.Copy ' copy the new sheet
        ExcelServer.activeworkbook.sheets("template").Name = NewSheetName ' set the new sheet name
        FileSaveName = ExcelServer.Application.GetSaveAsFilename _
        (InitialFileName:=Dwg_Name & ".xls", Title:="Save As")            ' choose where we're going to save it
        If FileSaveName = "False" Then                         ' error handleing
            MsgBox "File not Saved, Actions Cancelled."
            Exit Sub
        Else
            ExcelServer.activeworkbook.SaveAs FileSaveName ' save it
            ExcelServer.activeworkbook.Close               ' close it
        End If
        ExcelServer.Application.DisplayAlerts = False ' hide unwanted alerts
        ExcelServer.workbooks("bptags.xls").Close     ' close the work book
        ExcelServer.Quit                              ' quit excel
        set_to_nil                                    ' function to reset object variables to nothing
    End Sub
    This is my blog, fell free to drop by and look or correct
    http://showyourcode.blogspot.com/
Similar Threads
  1. Save command problems
    By STAN G in forum AutoCAD Beginners' Area
    Last Post: 2nd Mar 2012, 09:20 am
  2. Autocad doesn´t prompt to save, just save
    By gilsoto13 in forum AutoCAD Bugs, Error Messages & Quirks
    Last Post: 7th Apr 2010, 08:08 pm
  3. Load and Save problems
    By christreeroot in forum AutoCAD General
    Last Post: 1st Jun 2009, 03:30 pm
  4. AutoCAD PnID excel import problems
    By tomb020871 in forum P&ID
    Last Post: 30th Jun 2008, 09:59 pm
  5. Problems with render and save
    By Pocket in forum AutoCAD 3D Modelling & Rendering
    Last Post: 25th May 2007, 02:43 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
