Results 1 to 3 of 3
    Forum Newbie
    Inventor 2012
    May 2012
    1
    Default Formatting the standard toolbox spur gear
    Does anyone know how to modify the standard spur gear that comes with Toolbox? I'd like to enter my own values for pressure angle, pitch, etc. but I'm not sure how to do that.
    Thanks!
    Christopher
    Super Moderator fuccaro's Avatar
    AutoCAD 2006
    Nov 2002
    Romania, Marosvasarhely
    3,540
    I assume you are asking about Solidworks, so I moved your question here. Just post a message if it was a wrong decision.
    It's nice to be nice, but sometimes is nicer to be evil!.
    Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
    Forum Deity shift1313's Avatar
    not applicable
    Sep 2008
    VA
    2,859
    I made a few videos on modeling gears.
    http://www.mymlcservices.com/index.p...sort=0&ep=&ex=
    When you drag a spur gear from the toolbox into your assembly you should get a properties window on the left in your feature tree that lets you adjust all the properties of the gear that are available.
    Matt - Certified Solidworks Expert -Advanced Surfacing, Mold Tool and Sheet Metal Specialist
    Current Software: SolidWorks11,SolidCam11
    http://www.solidworkslessons.info/
    www.mysolidbox.com
  1. how to make a teeth of a spur gear
    By lulumara in forum AutoCAD 3D Modelling & Rendering
    Last Post: 15th Mar 2012, 02:55 pm
  2. Dynamic simulation of spur gear help !
    By Theja in forum Autodesk Inventor
    Last Post: 31st Oct 2011, 06:58 pm
  3. Spur Gear and Rack
    By amerdsp in forum Autodesk Inventor
    Last Post: 30th Sep 2010, 04:22 pm
  4. teeth of spur gear
    Last Post: 29th Apr 2007, 06:15 pm
  5. quick spur gear question
    By ncoop23 in forum Autodesk Inventor
    Last Post: 19th Sep 2006, 09:49 pm
