Results 1 to 7 of 7
    Forum Newbie
    AutoCAD 2011
    May 2012
    5
    Default Processing of multiple drawings - Script ends after first drawing
    I am running a script to process many drawings, and the script ends after the first drawing. I have tracked down the issue but do not know how to work around it:
    (c:test1 "10.DWG") _.open "10.DWG" (c:test2) _.qsave _.close
    (c:test1 "11.DWG") _.open "11.DWG" (c:test2) _.qsave _.close
    The problem seems to be trying to issue any command other than "open" after the initial drawing is loaded and closed. If I remove the "(c:test1)" from all lines after the 1st line, then it works fine. The details of test1 don't really matter, I've tried using a built-in AutoCAD command instead and the same problem happens.
    It's as if AutoCAD won't process any more script commands unless you immediately open another drawing after closing the previous one, in case the script closed the last drawing and there are no more open drawings to execute commands against. But that is not the case, Drawing1.dwg remains open the whole time.
    Since Drawing1.dwg remains open the whole time, I thought if I could find a command to "activate" or make it "current" again, then perhaps I could issue the test1 command prior to opening the next drawing, something like:
    activate "Drawing.dwg" (c:test1 "11.DWG") _.open "11.DWG" (c:test2) _.qsave _.close
    However, I've researched and cannot find any such "activate" command.
    FYI - I need to run the test1 function on the filename prior to opening the drawing.
    Any ideas on how to resolve this would be greatly appreciated. Thanks.
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,791
    When you open another dwg you transfer control to that dwg now so any new programs are run on that dwg and ignore prior dwg you would need to do some sort of change back to drawing1 if you want to do something in that dwg and bring it into the next dwg. What is C:test1&2 doing ?
    Forum Newbie
    AutoCAD 2011
    May 2012
    5
    Thanks for the reply. So I hope there is a way and someone can help with how to transfer control back to Drawing1 after closing a drawing. Test1 is doing some processing with a remote database using the filename, so it only needs the drawing filename, does not need the drawing open. Test2 is doing standard stuff on the drawing (turn layers on/off, etc.). The details of the functions don't seem to matter, same issue happens if I remove test2 and replace test1 with some standard AutoCAD command.
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,008
    Then how about doing the processing in two steps: (1) run a script in an empty drawing to perform the said database validation and (2) after run the processing script on the entire bunch?
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
  5. #5
    Forum Newbie
    AutoCAD 2011
    May 2012
    5
    I had thought about that and it is my plan B, but would be preferable to get it working in one step if possible, so that each drawing can be dispatched to a different business process without having to wait for the first step, which will take a long time (thousands of drawings). If it's just a simple matter of a command I need to insert (or something) to transfer control to Drawing1.dwg, then I would go that route.
    Thanks.
  6. #6
    Forum Newbie
    Civil 3D 2012
    Nov 2011
    Australia
    5
    Is there any reason you are not using scriptpro or autoscript?
  7. #7
    Luminous Being dbroada's Avatar
    dbroada's Computer Details
    XP Pro
    Dell
    Intel Xeon 2.13GHz
    2GB
    NVIDA Quadro FX 580
    DELL 23" & SAMSUNG 21"
    Electro/Mech
    dbroada's Discipline Details
    Design Engineer
    Electro/Mech
    Electrical 2013
    Nov 2005
    Sussex, UK
    5,071
    without reading everything you have done I run my scripts in SDI mode and finish with
    Code:
    qsave
    open <drawing name>
    "That's it. It's one thing for a ghost to terrorize my children, but quite another for him to play my Theremin." Homer Simpson
    Dave
  1. Drawing a line with one or two arrow ends
    By titech in forum AutoCAD General
    Last Post: 25th Oct 2012, 12:29 pm
  2. Insert a block in multiple drawings using script
    By Arek80 in forum The CUI, Hatches, Linetypes, Scripts & Macros
    Last Post: 14th Dec 2011, 03:02 am
  3. Lisp or Script - Procedure on Multiple Drawings?
    By ILoveMadoka in forum AutoLISP, Visual LISP & DCL
    Last Post: 22nd Aug 2011, 03:43 am
  4. Drawings form Multiple sources (multiple xrefs)
    By Gila in forum CAD Management
    Last Post: 28th May 2008, 03:17 pm
  5. Where one point on a drawing ends up on another
    By Siberian in forum AutoCAD Drawing Management & Output
    Last Post: 28th Jul 2006, 12:26 pm
