Results 1 to 4 of 4
    Senior Member Hardney's Avatar
    Civil 3D 2013
    Dec 2005
    Montreal, Qc
    172
    Angry .tmp file created at each saves
    Hi,
    all my temporary files are redirected to another disc when saves files such as .ac$ and .sv$ are created in order to not full my C:/ disk and have memory issues. But I realized that when I make a qsave or when an automatic save is done, a savXXXX.tmp is created that is saved on this location C:/Users/User/AppData/Local/Temp. The file added is named as follows: AecXXXX.tmp. I made sure that in the options File tab all my file locations for temp files and saves were where I wanted them to be (on my D:/ disk). Then I saw the Open and Save tab I had Create backup copy with each save check, so I unchecked it but this has done nothing...
    Can you help me because now I really have a hard time working for all the .tmp files are using 0.4Gb on my C:/ disk each time a save file is done and I have to delete them everytime for my working file is big because it is filled with gradings.
    Thank You
    Hardney
    Dying's for the rest of your life.
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,471
    And what is the capacity of your hard drive?
    How much free space do you currently have?
    How many drawings will you work on in any given day?
    Civil 3D 2013
    Dec 2005
    Montreal, Qc
    172
    Idea
    ReMark:
    Disk C:/ 78.1 Gb Free Space: 23Gb but decreases very rapidly as a 100 of .tmp files are created everytime I open my drawing.
    Disk D:/219 Gb Free Space:186Gb: This is where I make my .ac$ and .sv$ get saved.
    On a normal day, I can work from 5 to 10 .dwg, including the xrefs and the presentation plans in which the xrefs are in, when working on a single project.
    Hardney
    Senior Member Blackfish's Avatar
    AutoCAD LT 2012
    Apr 2012
    182
    I find deleting these files anyoing too; working in a network with synchonizing files on two servers these extra files make synchronization slower... But 100 no. of .tmp everytime you open a drawing it's extraordinary?
    Would it be possible from AutoCAD level delete these files with some macro or script (don't forget I'm LT user ) at the end of the day?
    LT is still AutoCAD
  1. How to change the default file directory where Autocad saves its files?
    By The Mad Cadder in forum AutoCAD Beginners' Area
    Last Post: 7th Nov 2011, 03:30 pm
  2. Replies: 1
    Last Post: 14th Jul 2011, 12:52 pm
  3. When open a file a lisp created in the same folder
    By asos2000 in forum AutoLISP, Visual LISP & DCL
    Last Post: 16th Jun 2011, 11:07 am
  4. Problem importing in Autocad a DWG/DXF file created in Archicad
    By frank87 in forum AutoCAD Beginners' Area
    Last Post: 7th Jun 2011, 09:45 pm
  5. dwt saves as dxf file
    By richie_008 in forum AutoCAD Beginners' Area
    Last Post: 12th Nov 2010, 10:53 am
Tags for this Thread
