Page 1 of 2 1 2 LastLast
Results 1 to 10 of 13
    Forum Newbie
    AutoCAD 2013
    May 2012
    5
    Default getting it to print 1:1 correctly
    Hi everyone, I am new here. A quick introduction. I am a primary school teaching living in Germany. My experience with apps like this are only with maya (I have an 3D animation degree as well). I am totally new to autocad and currently have little knowledge how to use it.
    I created a model in nurbs curves in maya as I know how to model in that program and then exported it to autocad. I did this as I want to print it out to scale. It was created in mm but I can't get it to print to scale (so 50 units = 50mm) any idea what i need to do?
    I have induced the file that I am using. It is the two top plates to a DIY quadcopter. boys and their toys.
    Super Member
    nestly's Computer Details
    Windows XP Professional (32bit)
    Intel DG33FB
    Intel Core2 E2220 @ 2.4GHz
    4GB DDR2 6400
    ATI Firepro 5800
    250GB WD 7200rpm / 320GB WD 7200rpm
    500GB WD external USB
    Samsung 26" @ 1920x1200 + LG 22" @ 1680x1050
    AutoCAD 2011
    Sep 2010
    1,895
    Open the Plot Dialog box
    Pick your Plotter/Printer
    Pick your Paper size
    Uncheck Fit to Paper
    Make sure the scale is 1:1 so 1 mm = 1 unit
    It may also be helpful to use "Window" under "What to Plot" to center your objects on the paper
    Make sure to use the preview to verify before you plot.
    Having said that, if you're going to plot from AutoCAD with any frequency, I would create a paperspace layout for your plotter/paper, and plot from there, rather than directly from modelspace, as you'll be able to preview your plot at scale as it will appear on the paper before even entering the plot dialog.
    Forum Newbie
    AutoCAD 2013
    May 2012
    5
    Quote Originally Posted by nestly View Post
    Attachment 35031
    I have tried this but all I get is my object being very small in the bottom left corner. I tried changing the values around but couldn't get it right. I have used the dimension tools to measure areas that I know the distance off and they were correct. ( a square I have is 50 units).
    I am unsure what you mean by - use "Window" under "What to Plot" to center your objects on the paper.
    Forum Deity rkent's Avatar
    rkent's Computer Details
    WIN7 PRO 64bit
    Dell Precision T7500
    Xeon Dual Core E5503 2.0Ghz
    6GB DDR3 ECC SDRAM, 1333MHz, 6x1GB
    nVidia Quadro 3800
    300Gb, 10K rpm
    Dell 24" FS (2x)
    Mechanical
    rkent's Discipline Details
    Mechanical
    Mechanical 2014
    Nov 2007
    3,371
    Your viewport in the layout is not set to 1:1, you will need to make a much bigger viewport or stretch that one much larger and set the viewport scale to 1:1.
    "You are entitled to your own opinion but you are not entitled to your own facts." Daniel Patrick Moynihan
  5. #5
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    nVidia Quadro 4000, 2GB GDDR5
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    I think you may have used an imperial template and not a metric template when you did your drawing because all I see in your scale list are imperial scales like 1/128"=1'-0" to 1'-0"=1'-0". I'm not seeing scales like 1:20, 1:50, 1:100, etc.
  6. #6
    Super Member
    Intel DG33FB
    4GB DDR2 6400
    ATI Firepro 5800
    AutoCAD 2011
    Sep 2010
    1,895
    Upon further review, I think that's an Imperial template, which is why the paper/viewport is so small compared to the model.
  7. #7
    Forum Newbie
    AutoCAD 2013
    May 2012
    5
    that is true. How do I go about fixing that?
  8. #8
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    First you would have to open a new drawing using either one of the default metric templates that AutoCAD comes with or one that someone else created. Then you would have to copy/paste from the old drawing to the new and scale your objects accordingly.
  9. #9
    Forum Newbie
    AutoCAD 2013
    May 2012
    5
    Sweet that fixed it. copied it over. set the scale to 1:1 and bingo I am now in action. Thanks very much guys.
    I do have a build log at
    http://www.rcgroups.com/forums/showthread.php?t=1657109
    if you want to see more of what I am doing. Nothing much until after friday. I have a german language test
  10. #10
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2013
    Nov 2005
    Norwalk, CT USofA
    33,026
    Wunderbar!
  1. Cannot Print Colour, Crunched up Text, Restricted Print Field
    By D1-Xen in forum AutoCAD Drawing Management & Output
    Last Post: 14th May 2012, 06:46 am
  2. Scaling Layouts Correctly
    By Hoover in forum AutoCAD Beginners' Area
    Last Post: 5th Jan 2009, 09:33 pm
  3. Print Preview and Print does not equal Drawing
    By reggy in forum AutoCAD General
    Last Post: 19th Aug 2008, 03:53 am
  4. Custom Linetype Won't Print Correctly
    By CatCup in forum AutoCAD Drawing Management & Output
    Last Post: 24th Apr 2008, 03:02 am
  5. using layouts correctly
    By east§ide in forum AutoCAD Beginners' Area
    Last Post: 18th Oct 2007, 06:00 pm
