am having trouble writing a macro for the alignment of text to an existing line orientation, has anyone already done this by any chance?
Your profile states that you are using LT; therefore I have to presume that you are talking about a macro for a toolbar button. I’m really not sure if you can achieve that – it is supposed to require a kind of calculation of the base line orientation, which I really don’t see how can be done in button’s macro without AutoLISP support.
Regards,
Mircea
AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
What is wrong with ALIGN command?
LT is still AutoCAD
If you don't mind an interactive solution, then may check if this is useful to you.
Regards,
Mircea
Not sure if this works in LT UCS OB pick line do text UCS W make sure ortho is on. this will allow text at 0 90 etc to line. You can add a button or menu or macro to do UCS OB
It's nice to be nice, but sometimes is nicer to be evil!.
Tip: Please do not PM or email me with CAD questions - use the forums, you'll get an answer sooner.
BIGAL, thank you for the great idea: UCS OB! I didn't know how to get an angle from single-line text, because there is only one insertion point, and with Diesel and macro you are very limited, but as always we should try...
I did it the other way, because I don't understand what do you mean by 'do text UCS W'. Would be nice to just select line instead of picking two points, but I have no idea how to improve the below code.
So, I did.
Maybe something could be better but as a start I'm quite happyCode:^C^C_ucs;n;ob;\^C^C_move;@;;0,0;\^C^C_rotate;p;;@;\^C^C_ucs;p;
PS. Almost as usually no OP's cooperation![]()
LT is still AutoCAD
I thought you were trying to add text but to an existing line for orientation rather than alter existing.
Any way the Ucs W, User Co-ordinate System WORLD, mosts times when you start a dwg you are in the "world" setting, if you crash your macro you may need UCS W but UCS P "previous" is a good way to go if your playing with different ucs's. Also another quickie for lots of text "UCS Ob plan" pick all text use "modify" set angle to 0 then "UCS P plan" bit quicker maybe than typing 47d23'35" after you have found out the correct angle.
