Results 1 to 9 of 9
    Senior Member
    AutoCAD 2006
    Aug 2009
    109
    Default point orientation
    Hi All,
    I have added a point using
    Code:
    ThisDrawing.ModelSpace.AddPoint(pnt)
    Then Rotated the point using
    Code:
    pnt.Rotate p, somevalue
    Now how can i read the current rotation value of the point?
    **The dxf code 50 representing the Rotation value.
    Thanks,
    Kumar.
    Forum Deity BlackBox's Avatar
    Civil 3D 2011
    Nov 2009
    4,045
    'ThisDrawing'... sounds like a VBA thang... then this thread may help:
    http://forums.autodesk.com/t5/AutoCA...BA/td-p/621912
    "Potential has a shelf life." - Margaret Atwood
    Senior Member
    AutoCAD 2008
    Nov 2005
    Bulgaria, Sofia
    228
    It doesn't seems like the point object in VBA has no .Rotation property at all. It is just a point. To have a rotation you should better use a block containing a point or just any kind of block.
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    Search for DUMPENT.lsp good for finding out all sorts of stuff about an object and naming for VL & VBA will confirm if rotation supported.
  5. #5
    Civil 3D 2011
    Nov 2009
    4,045
    Code:
    (defun c:DUMP  ( / eName)
      (if (setq eName (car (entsel "\nSelect object: ")))
          (vlax-dump-object (vlax-ename->vla-object eName) T)
          (textpage))
        (prompt "\n** Nothing selected ** "))
      (princ))
  6. #6
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    Thanks Renderman didn't have that lisp at time of post. Dumpfor a Autocad point does not appear to have rotation. NOTE CIV3D point is totally different
    Code:
    Select object: ; IAcadPoint: AutoCAD Point Interface
    ; Property values:
    ;   Application (RO) = #<VLA-OBJECT IAcadApplication 000000013fdc2308>
    ;   Coordinates = (613.794 53.8048 0.0)
    ;   Document (RO) = #<VLA-OBJECT IAcadDocument 0000000026ac7068>
    ;   EntityTransparency = "ByLayer"
    ;   Handle (RO) = "116C2"
    ;   HasExtensionDictionary (RO) = 0
    ;   Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000003768f208>
    ;   Layer = "DEFAULT"
    ;   Linetype = "ByLayer"
    ;   LinetypeScale = 1.0
    ;   Lineweight = -1
    ;   Material = "ByLayer"
    ;   Normal = (0.0 0.0 1.0)
    ;   ObjectID (RO) = 87
    ;   ObjectID32 (RO) = 87
    ;   ObjectName (RO) = "AcDbPoint"
    ;   OwnerID (RO) = 88
    ;   OwnerID32 (RO) = 88
    ;   PlotStyleName = "ByLayer"
    ;   Thickness = 0.0
    ;   TrueColor = #<VLA-OBJECT IAcadAcCmColor 00000
    Select object:
    00037684520>
    ;   Visible = -1
  7. #7
    Civil 3D 2011
    Nov 2009
    4,045
    You're welcome; I have a slew of Dump* and Entget* functions for various objects. I'd be happy to share if you'd find them useful.
    ** Edit - I do need to add Civil 3D specific support though; many of the Aecc* objects are not even supported by vlax-dump-object. I'm going to need to code some .NET LispFunction Methods to expand LISP for this.
  8. #8
    Forum Deity
    Civil 3D 2013
    Dec 2005
    GEELONG AUSTRALIA
    3,798
    Renderman your mailbox is full can not send you some help for AECC CIV3d
  9. #9
    Civil 3D 2011
    Nov 2009
    4,045
    Quote Originally Posted by BIGAL View Post
    Thanks Bigal; inbox cleaned up (enough), fire away! LoL
    Cheers
  1. Linetype Orientation
    By JORYROJ in forum AutoLISP, Visual LISP & DCL
    Last Post: 10th May 2012, 08:19 pm
  2. Replies: 1
    Last Post: 29th Aug 2011, 10:00 pm
  3. Replies: 0
    Last Post: 29th Aug 2011, 09:52 pm
  4. Drawing orientation
    By MisterJingles in forum AutoCAD Drawing Management & Output
    Last Post: 21st Jan 2010, 10:19 am
  5. Orientation
    By Peter K in forum SolidWorks
    Last Post: 29th Apr 2009, 01:59 pm
