+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
  1. #11
    Super Member RobDraw's Avatar
    Using
    AutoCAD 2011
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    1,210
    Default
    Quote Originally Posted by madriver View Post
    Still, I wish you could determine what the error is.
    I can't verify this at the moment but I believe audit reports any errors to you at the command line. Hit F2 to toggle your AutoCAD Text window.
    Rob
  2. #12
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,092
    Default
    Quote Originally Posted by RobDraw View Post
    That would correct.
    Code:
    Command: _audit
    Fix any errors detected? [Yes/No] <N>: y
    Auditing Header
    Auditing Tables
    Auditing Entities Pass 1
    Pass 1 3200    objects audited
    AcDbLeader(48139) annotation id Bad mtext id            Disable annotation
    AcDbLeader(4813B)   annotation id Bad mtext id          Disable annotation
    AcDbLeader(4813D)   annotation id Bad mtext id          Disable annotation
    Pass 1 7600    objects audited
    Auditing Entities Pass 2
    Pass 2 7600    objects audited
    Auditing Blocks
     220     Blocks audited
    Total errors found 3 fixed 3
    Erased 0 objects
  3. #13
    Forum Deity Dadgad's Avatar
    Using
    AutoCAD 2012
    Join Date
    Nov 2011
    Location
    At the confluence of worthlessness & invaluability
    Posts
    3,131
    Default
    Yep, right you are there Rob, never noticed it before.
    Volume and repetition do not validate opinions forged in the absence of thought.
Similar Threads
  1. Purge / Audit
    By marbruce in forum AutoCAD General
    Last Post: 15th Feb 2011, 02:53 pm
  2. $audit-bad-layer
    By salmonrose in forum AutoCAD Beginners' Area
    Last Post: 3rd Dec 2009, 05:20 pm
  3. Standards Audit
    By Dman2900 in forum AutoCAD Drawing Management & Output
    Last Post: 6th Aug 2008, 06:15 pm
  4. Audit
    By Simple153 in forum AutoCAD Drawing Management & Output
    Last Post: 15th Oct 2007, 07:41 pm
  5. Audit not Working???
    By WannaBeCader in forum AutoCAD Drawing Management & Output
    Last Post: 26th Feb 2005, 12:23 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
