Page 1 of 2 1 2 LastLast
Results 1 to 10 of 17
    Full Member
    AutoCAD 2008
    Nov 2011
    47
    Default Maintaining JPEG Paths
    Hello Forum,
    I prepare drawings for a client which include .jpeg images as part of the final product. The problem is: When I work on these drawings from my home office, I need to re-establish the .jpeg's path in order to work on the drawing. Then when I send these drawing files back to my client, they need to re-establish the .jpeg's path on their end in order to display the drawing properly. My client and I would like very much to be able to avoid this "re-establishing paths" step, where we can each open the drawing file on our computers and immediately see the jpeg image as part of the drawing. Any suggestions would be greatly appreciated - thanks! - Dave
    Forum Deity MSasu's Avatar
    Construction
    MSasu's Discipline Details
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    When attach the images you should chouse Relative Path instead of Full Path.
    Regards,
    Mircea
    AutoCAD's happy user equation: FILEDIA + PICKADD² + PICKFIRST = 3
    Full Member
    AutoCAD 2008
    Nov 2011
    47
    Thanks Mircea. Unfortunately, I don't fully understand how to choose "Relative Path" instead of "Full Path". Can you please clarify this process a bit for me? Is this something that I can change in the .jpeg's "setting" now, without having to re-insert it?
    Thanks again - Dave
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    Seems that the option isn't availble in Properties, so I'm afraid that you should re-insert them. Will check later for you to see if this cannot be solved by AutoLISP.
    Regards,
    Mircea
  5. #5
    Full Member
    AutoCAD 2008
    Nov 2011
    47
    Thank you Mircea, any additional information (AutoLISP) would be greatly appreciated - especially if it works!
    Dave
  6. #6
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    Just found the solution: call Reference Manager tool (will find it in Start --> Programs --> Autodesk --> AutoCAD 20?? -- > Reference Manager), load the drawing(s) containing the images you want to edit their path to relative and change the Saved Path entry to "." (dot). The said field should contain the full path now.
    Regards,
    Mircea
  7. #7
    Full Member
    AutoCAD 2008
    Nov 2011
    47
    Thank you for all of your help, Mircea! - Dave
  8. #8
    Construction
    engineer
    Construction
    AutoLISP programmer
    AutoCAD 2013
    Mar 2009
    Brasov, Romania
    3,007
    You're entirely welcome Dave!
    Regards,
    Mircea
  9. #9
    Full Member
    AutoCAD 2008
    Nov 2011
    47
    Hi, I am returning to a thread that I began back in June - hopefully this is easy enough for someone to pick up on. It is my understanding that when using "relative path" for jpeg insertion that the jpeg not only needs to exist on my computer, it needs to reside on my clients computer also. Therefore, I have created a subfolder on my computer which contains the CAD drawing and the jpeg that is attached to it. I have also created a subfolder on my clients computer which contains the same CAD drawing and the jpeg that is attached to it. However, when the drawing file is accessed at my clients computer, the jpeg does not appear. Can somebody help me with solving this dilemma?
  10. #10
    Super Member Organic's Avatar
    Civil
    Civil 3D 2013
    Feb 2009
    1,641
    It should work. If the client is opening the file as an email attachment or not saving it in the correct location it wouldn't work.
    Try the e-transmit tool and see if he can get it to work with that.
  1. Maintaining text orientation with copyclip/paste into different UCS
    By xr309 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Oct 2011, 04:27 pm
  2. autocad to photoshop maintaining same layers
    By akansha in forum AutoCAD Beginners' Area
    Last Post: 24th Sep 2007, 11:51 pm
  3. Maintaining layer status when using nested xrefs
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 28th Feb 2007, 06:50 pm
  4. Maintaining layer setup when X-ref'ing a file w/x-refs
    By Disgruntled Architect in forum AutoCAD Beginners' Area
    Last Post: 20th Dec 2005, 03:59 am
  5. maintaining a proper scale when increasing plot size
    By tylermcg62 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jun 2005, 10:23 am
