+ Reply to Thread
Page 2 of 2 FirstFirst 1 2
Results 11 to 17 of 17
  1. #11
    Computer Details
    SLW210's Computer Details
    Operating System:
    Windows 7 PRO
    Computer:
    IBM Lenovo
    Motherboard:
    ACPI x86
    CPU:
    Pentium(R) Dual-Core CPU E5500 @ 2.80GHz
    RAM:
    4 GB RAM
    Graphics:
    Nvidia Quadro 600 1GB
    Primary Storage:
    300 GB
    Secondary Storage:
    650GB
    Monitor:
    ThinkVision 22"
    Discipline
    Multi-disciplinary
    SLW210's Discipline Details
    Occupation
    Design Draftsman
    Discipline
    Multi-disciplinary
    Details
    Using
    AutoCAD 2011
    Join Date
    May 2007
    Location
    South Florida, USA
    Posts
    9,099
    Default
    Why not Paste the jpeg into the drawing? Just open the jpeg in a drawing editor, e.g., MS Paint, etc. and Copy, then Paste in drawing.
  2. #12
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Nov 2011
    Posts
    47
    Default
    Hi Mircea. This reply goes back to a discussion that I began last June, in which you assisted me with. My client and I finally had an opportunity to put "relative path" vs. "full path" to the test, regarding jpeg files. The "relative path" approach works great; my client and I thank you very much for the guidance you have given us!
  3. #13
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Nov 2011
    Posts
    47
    Default
    Regarding the use of "Relative Path": Sometimes I receive an error message that reads: "Relative Path Cannot Be Assigned". Can someone help me understand what needs to be done to allow "Relative Path" to be used?
  4. #14
    Super Member RobDraw's Avatar
    Using
    AutoCAD 2011
    Join Date
    Apr 2007
    Location
    Connecticut, USA
    Posts
    1,212
    Default
    I see that message sometimes and a save usually lets you do it. If not, then close and reopen.
    Rob
  5. #15
    Forum Deity
    Using
    AutoCAD 2002
    Join Date
    Sep 2006
    Location
    East Sussex, U.K.
    Posts
    2,965
    Default
    I have found that if the jpg is in the same folder as the drawing, then AutoCAD will look in the current folder before it goes hunting elsewhere.
  6. #16
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Nov 2011
    Posts
    47
    Default
    Thanks Rob, I will give that a try. I too have found, from time to tme, that saving my drawing usually allows the relative path thing to work. When it doesn't next time, I will try the "close and reopen" approach.
  7. #17
    Full Member
    Using
    AutoCAD 2008
    Join Date
    Nov 2011
    Posts
    47
    Default
    Thanks Eldon, I will give that method a try!
Similar Threads
  1. Maintaining text orientation with copyclip/paste into different UCS
    By xr309 in forum AutoCAD 2D Drafting, Object Properties & Interface
    Last Post: 7th Oct 2011, 04:27 pm
  2. autocad to photoshop maintaining same layers
    By akansha in forum AutoCAD Beginners' Area
    Last Post: 24th Sep 2007, 11:51 pm
  3. Maintaining layer status when using nested xrefs
    By Autodesk in forum AutoCAD RSS Feeds
    Last Post: 28th Feb 2007, 06:50 pm
  4. Maintaining layer setup when X-ref'ing a file w/x-refs
    By Disgruntled Architect in forum AutoCAD Beginners' Area
    Last Post: 20th Dec 2005, 03:59 am
  5. maintaining a proper scale when increasing plot size
    By tylermcg62 in forum AutoCAD Drawing Management & Output
    Last Post: 17th Jun 2005, 10:23 am
Posting Permissions
  • You may not post replies
  • You may not edit your posts
