Results 1 to 7 of 7
    Senior Member asptamer's Avatar
    AutoCAD 2007
    Apr 2006
    116
    Default Level of detail in a drawing
    Here's what I mean by level of detail:
    Arcs are nice and smooth when you draw them, but if you close and open the file again, the drawing becomes optimized. Arcs looks like two straight lines, zigzag lines look like straight lines, etc.
    In AutoCAD2000/LT this could be fixed by clicking "Layout" tab and then going back to "Model." But I've upgraded to 2005 and this no longer works. The only method I've discovered is to move the object - then arcs and lines become what they were originally drawn as.
    I understand that this is only visual - the printout will be proper - but I'd like to know if there's a simple way in AutoCAD 2005 to increase the level of detail in a drawing - permanently or when needed. Please help.
    Super Moderator rkmcswain's Avatar
    rkmcswain's Computer Details
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Check setting of WHIPARC, SHADEMODE, and then run VIEWRES command. Look these up in HELP for more info.
    Senior Member
    AutoCAD 2005
    Dec 2005
    Brandon, Manitoba, Canada
    166
    What is the system variable VIEWRES set to?
    If it too low you may encounter this problem.
    Try setting it higher, or try doing a regenall.
    Thalon
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by thalon
    VIEWRES is not a system variable.
  5. #5
    AutoCAD 2007
    Apr 2006
    116
    VIEWRES is what I was looking for. Thanks!
    Now, is there a way to override the default value of 100 so that when I restart AutoCAD and open a file, it's 1000 right away, without me setting it manually?
  6. #6
    Windows 7 Pro x64
    Intel DZ77RE-75K
    i7-3770K 3.50GHz
    32GB
    Nvidia Quadro 2000
    125GB SSD
    500GB SATA
    ASUS 27" / ASUS 24"
    Civil
    Civil 3D 2013
    Sep 2005
    Houston
    3,633
    Quote Originally Posted by asptamer
    Set it in your template drawing (for new drawings)
    For existing drawings, add this:
    Code:
    (command "._viewres" "_y" "1000")
    ...to your S::Startup function in "acad.lsp"
  7. #7
    AutoCAD 2007
    Apr 2006
    116
    thank you : )
