Page 2 of 7 FirstFirst 1 2 3 4 ... LastLast
Results 11 to 20 of 68
  1. #11
    ReMark's Computer Details
    Windows 7 Pro 64-bit
    Thinkmate
    Intel DX58SO2 LGA1366 X58
    12GB (3x4GB) PC3-106000 DDR3
    none
    See details...
    ReMark's Discipline Details
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,616
    Dadgad:
    Were you thinking "French" doors where you have indicated double doors?
    That's still a lot of doors. I'd eliminate one set but keep the wider opening as it is more inviting. Take your pick.
  2. #12
    AutoCAD 2013
    Nov 2011
    5,985
    Quote Originally Posted by daft vader View Post
    Dadgad that a good design, it would be easy to change,I take it the red lines would be a overhanging roof line yes? that could be good for shade in the summer as that is facing west so it's sunny in the afternoon.
    BTW i do not draw plans I only ever alter existing drawings, so yes its a mess that's why I am asking for help here, I do not even know what "AEC objects" are.
    Remark we do not have bedroom closets as a rule they are free standing wardrobes, if you check out the floor plan there are only 2 cupboards in the building, and even that is a lot as most modern bungalows over don't have any at all as we found out while house hunting, I just wished I lived in your counrty as I could buy a lot bigger house/bungalow over in the USA for less money then here thats for sure, only today on the tv that were showing a holiday bungalow in florida with 3 beds with unsuites and a really big lounge kitchen etc for £65,000 its me costing £165,000 for my 2 bed as it is on the plans
    Without knowing anything about your roof, except that it was pretty close to square I added a 500mm overhang from the exterior walls and found the center point as you mentioned it was a symmetrical pyramid roof shape.
    I first drew it with the same 500mm roof overhang, then added the red option which would give you 2 meters clear of the exterior walls for weather and sun protection. It would also make the inside seem larger by visually incorporating the external covered space. All of the roofs conform with the existing pitches, and a bare minimum of structural changes to the roof framing. Win win.
    By closing the old kitchen doorway, that closet can become quite a bit larger which will help, and the connectivity of the kitchen makes the living, dining and kitchen areas all feel bigger by extension.
    AEC objects are the dynamic elements, the walls, windows, doors, etc. which are supposed to interact nicely together, and do if their dynamic attributes are operating correctly.
  3. #13
    AutoCAD 2013
    Nov 2011
    5,985
    Dadgad:
    I would lose the 2 sets of double doors going into the living room, and just have arched openings, much better.
    Once you do that, close the closet door(as it would normally be & in plan view) in front of the bathroom, or go sliding on that one, then the french doors give it a touch of class, opening in, as they are entry doors.
    Sure the most space efficient and cheapest way would be a big ugly sliding glass door there, which would take up no space and provide a lot of light, but none of the charm.
  4. #14
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,616
    French doors are much more classy, I agree. Sliding doors are so 60's.
  5. #15
    Senior Member
    not applicable
    Nov 2006
    Melbourne Australia
    245
    Doors can be handy to zone heating. DV hasn't mentioned which part of the UK he's in and it may be an issue. Sliding doors are also a headache to maintain and are noisy - go with the french and make sure they can fold flat when open.
    Dadgad's idea to marry the new roof with the old will work far better than adding a flatroof (from rueful experience). Getting matching tiles can be a tough ask but it's not going to be visible from the street.
    DV, if you can, have a look at how the roof is supported - check that the walls you are taking out do not hold up the roof in any way. Also while you are there get some actual measurements of the affected area before doing much more planning.
    Who best to approach in the UK for on-the-ground assistance? Here on Oz I'd ask a builder or an architect with some design ability who can indicate the cost of their services.
  6. #16
    Senior Member daft vader's Avatar
    MEP 2008
    Jul 2006
    uk
    171
    Thanks guys but untill i have the keys in my hands i am only thinking ahead.
    Open planning is not so big in the Uk we like to keep our heating bills down as much as we can with closed doors in the winter open as much in the summer (no air-con here ).
    Flat roofs are used a lot over here we tend to use Fibreglass or Rubberbond now as it last longer then Traditional felts that were use to be used before and you get 25years guarantee unlike 5 -10 years for felt.
    I still have not seen a reply to my first question of how much will it cost for building regs drawings please ?
  7. #17
    AutoCAD 2013
    Nov 2011
    5,985
    Here is what I was thinking, as a rough outline. Doors show nothing more than handing and rough widths, clearly the french doors would want to be glazed and unencumbered at their center (no post).
  8. #18
    MEP 2008
    Jul 2006
    uk
    171
    Thats looking good Dadgad, would it work having the end wall with the doors and the new side wall facing down the drawing all glass ? I am thinking frameless full height glass it would put a lot of light into the kitchen/dining room if that could be done, I assume it would have to be a metal frame work to support the roof ? it would be like a built in Conservatory with a solid roof would be cooler in the summer ?
    A bit like the attached photo
  9. #19
    Thinkmate
    none
    See details...
    See details below.
    AutoCAD 2018
    Nov 2005
    Norwalk, CT USofA
    46,616
    What are the ceiling heights in this house? Do they approach 3 meters? With the right construction techniques I don't see the cost of heating the rooms as being a significant obstacle to overcome. Isn't the house insulated as well? I can't see where having a double-wide opening between the kitchen and lounge would be problem heating-wise. What is the heating source?
  10. #20
    MEP 2008
    Jul 2006
    uk
    171
    Remark ceiling heights are about 2.4mts, and yes in the UK walls and roof are well insulated, but we dont tend to over heat rooms the kitchen wouldnt be kept the same temp as the lounge and bed rooms would be cooler as well, we have gas condensing boilers and wet radiators with TRV (temp regulating valves) so each room is heated to the right temp so doors tend to be kept shut for that reason
  1. .dga file extension?
    By Longchamp in forum Catch All
    Last Post: 18th Mar 2010, 07:40 pm
  2. 'extension' OSNAP help
    By jsdrftng in forum AutoCAD General
    Last Post: 17th Nov 2009, 10:50 pm
  3. new wastewater extension for MEP
    By dumfatnhappy in forum MEP
    Last Post: 18th Dec 2008, 07:36 pm
  4. Bungalow plans...
    By jules_s in forum AutoCAD Drawing Management & Output
    Last Post: 19th Feb 2008, 10:44 am
  5. Line Extension Add-on
    By scotty in forum AutoCAD Drawing Management & Output
    Last Post: 1st May 2005, 03:39 am
